Old 10-26-2011, 07:55 PM   #1
CC33
CC33's Avatar
Default Looking to add dual temp gauges
I am looking to add dual temp gauges under the dash. Currently has a '36 motor with rebuilt water pumps, still 6 volt. What type of senders and gauges should I use, and how are they wired?
CC33 is offline   Reply With Quote
Old 10-26-2011, 09:01 PM   #2
B Duncan
B Duncan's Avatar
Default Re: Looking to add dual temp gauges
I am running mechanical Stewart Warner dual temp gauges. I have a 3 space cluster with the driver head on the left, oil pressure in the middle and the passenger head on the right side. With 180 deg. T-stats the driver side runs a lil over 165, and the passenger runs a lil over 175. As far as lighting goes, you can probably use 6 volt dash light bulbs.
Brad Duncan
B Duncan is offline   Reply With Quote
Old 10-26-2011, 09:03 PM   #3
Tinker
Tinker's Avatar
Could run mechanical gauges. No wiring outside of night lighting.
Old 10-26-2011, 09:19 PM   #4
peewee2you
peewee2you's Avatar
I just installed a pair of VDO Classic Series mechanical and bracket.
attached some photo's
peewee2you is offline   Reply With Quote
Old 10-26-2011, 10:13 PM   #5
CC33
CC33's Avatar
These analog gauges don't require power? Just the sender to gauge?
These look like they might work out.
http://www.summitracing.com/parts/SW...0-72/?rtype=10
Old 10-26-2011, 10:24 PM   #6
peewee2you
peewee2you's Avatar
CC33
Yes those guages from summit look like they would work fine. The ones from VDO in the pic, have a lite, but I am not going to use it, so no power needed either. The guages are mechanical and use a capillary tube for the water to travel to the guage, they were $39.00 each from, Summitracing or Jeggs.
Old 10-27-2011, 06:53 AM   #7
Mike51Merc
Mike51Merc's Avatar
Originally Posted by peewee2you View Post
CC33
You can get a 6V bulb for the light. By the way, mechanical gauges don't move "the water" (at least not the engine coolant) to the gauge. They are self contained.
Mike51Merc is offline   Reply With Quote
Old 10-27-2011, 07:51 AM   #8
Vic Piano
Vic Piano's Avatar
Does the '36 have two temp sending unit locations (one in each head)? I installed a mechanical temp gauge in our '39 (it has only one outlet in the driver’s side head). I installed two mechanical temp gauges in our '53 F-100 Panel Truck (it has two outlets, one in each head).
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 10-27-2011, 08:22 AM   #9
CC33
CC33's Avatar
Looks like the location for the sender is in the neck of the water pump.
Old 10-27-2011, 11:00 AM   #10
peewee2you
peewee2you's Avatar
Mike51merc, thanks for the correction in regards to water traveling to guage, it is sealed.
Old 10-27-2011, 12:41 PM   #11
Matt in Alameda
Why not use one gauge and two senders hooked up to a double throw switch? That is what I did.......haven't got the car running yet, but sure am getting close....Matt in Alameda
Matt in Alameda is offline   Reply With Quote
Old 10-27-2011, 12:46 PM   #12
deuce5wndw
deuce5wndw's Avatar
I just put two stewart warner gauges on a 1936 flathead. My RH water pump didn't have the temp sender hole so I used another LH water pump on the RH side. The threads on the gauge fittings were the same thread as in the water pumps and had a shoulder at the bottom of the water pump hole so I didn't have to use adapter fittings.
deuce5wndw is offline   Reply With Quote
Old 10-27-2011, 01:37 PM   #13
CC33
CC33's Avatar
That's exactly what I have. Two left side water pumps. Did you have any clearance issue with the sender going in on the right? Nice to know the threads are the same.
Old 10-27-2011, 07:01 PM   #14
deuce5wndw
deuce5wndw's Avatar
No clearance problem at all, I like the idea of two gauges so if you have a problem you know which side it's on.
Old 10-27-2011, 07:44 PM   #15
Brendan
Brendan's Avatar
CC33
those are good ones also, i have run them on a few garbage truck motors that i had!
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 10-28-2011, 04:56 AM   #16
flatmotor40
flatmotor40's Avatar
I screwed a set of Mon guages in the heads and I can read them when I think is is running hot but I took stats out and it runs way cooler
flatmotor40 is offline   Reply With Quote
Old 10-28-2011, 06:51 AM   #17
Tom in TN
Tom in TN's Avatar
Two mechanical gauges works good for me. Running a 36 motor in a 34 car.
Tom in TN is offline   Reply With Quote
Old 10-28-2011, 04:19 PM   #18
rick r
rick r's Avatar
as others have suggested, mechanical guages are a good choise, get the ones with 270 degree sweep. they give a more precise reading. i used SUNPRO which are available at most parts stores. they were less than $20 a few years ago. Personally i would not use stewart warner. from what i understand they are assembled in mexico from ??????> parts by a company out of pa. called maxima technologies. the words CUSTOMER SERVICE is not in their vocabulary. (just my personal experience)
rick r is offline   Reply With Quote
Old 10-29-2011, 11:31 AM   #19
Slick Steve
http://www.genosgarage.com/prodinfo....mber=WM-DUALTP
This is what I am going to use. Its from Westach. Seems to be perfect for this!
"Street rods have a Chevy in front and a can of wax in the back.......Hot Rods have a Flathead in front and a box of tools in the back"-- Fred Offenhauser
Check out my blog on my Flathead project!
http://myav8.blogspot.com/
Slick Steve is offline   Reply With Quote
