Old 08-12-2022, 02:59 PM   #1
waynes
Default 1950 car Seat Mounting Bolts
Anyone know size of bolts that hold front seat to frame rails in a 1950 Ford Car?
waynes is offline   Reply With Quote
Old 08-13-2022, 05:04 PM   #2
Flathead
Flathead's Avatar
Default Re: 1950 car Seat Mounting Bolts
Maybe 3/8 coarse thread?? Been a long time since I had my 50.
Flathead is offline   Reply With Quote
Old 08-13-2022, 06:40 PM   #3
joe 1950
joe 1950's Avatar
if i remember correctly they are 5/16 coarse thread because you use a 1/2 inch wrench
joe 1950 is offline   Reply With Quote
Old 08-16-2022, 10:10 AM   #4
waynes
I'll try each size to get it right, thanks.
Old 08-16-2022, 11:16 AM   #5
Dan in MI
Dan in MI's Avatar
Body parts catalog shows a 3/8-16 x 2” bolt with lock and flat washers.
Dan in MI is offline   Reply With Quote
Old 08-17-2022, 08:36 AM   #6
wga
wga's Avatar
Those seat bolts pass through the body mounts into the frame, so be careful the rubber
biscuits and a shim or two do not move. Although they are most likely corroded to the body or the frame.
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 08-17-2022, 08:39 AM   #7
wga
wga's Avatar
Dan has the correct info. Also be careful that the body mount rubber biscuit and possible
shim(s) do not move, as the bolt passes through the mount and into the frame. Likely
the rubber is corroded and 'fused' to either the body or the frame.
