10-16-2016, 01:11 PM | #1 |
Aftermarket starter motor 272 Y block
Hello all, seems my starter slowly giving up the ghost and i will be needing replacment have 3 speed colum shift box is a 3HD any particular makesout there you used pleasae?
10-16-2016, 03:14 PM | #2 |
Re: Aftermarket starter motor 272 Y block
I've used the Power Master starters.
Small, light & much easier to install |
10-16-2016, 05:07 PM | #3 |
many thanks, are they different for auto/manual please?
10-16-2016, 06:42 PM | #4 |
I don't think so
10-18-2016, 03:43 PM | #5 |
Find a local auto electric shop and go see them. You'll be way better off to use your own core and have them do their magic.
10-22-2016, 05:30 PM | #6 |
10-22-2016, 07:31 PM | #7 |
11-12-2016, 09:13 PM | #8 |
Mummert offers a what he calls "permenent magnet" starter for $239
11-13-2016, 09:51 AM | #9 | |
Best bet is still an auto electric shop, a starter is a starter. They all work pretty much the same regardless of who made it. Outside of a rare instance where a case or nose cone is bad, they should be able to fix it even in the UK. |
11-13-2016, 05:49 PM | #10 |
cheers for replys, i emailed mummet to name but a few and notany replies, have this coming from us, ebay cannot wait as mine dying
11-14-2016, 07:11 PM | #11 | |
That's the same one that I bought out of the states. Very easy fit, though as I said on another post it is only supported by the two ears that you bolt it through. Worked alright though, I just didn't think it was terribly robust as the base plate is aluminium and I was worried about it breaking one of those mounting ears. I ended up putting the original back in. The mini starter did sound weird starting as well.
Rick West Australia 1958 Ford Mainline Utility, 1955 Ford Tudor Sedan Quote:
