04-25-2011, 09:29 AM | #1 |
Correct "swan" neck shifter rod?
Guys, I've been told that my '39 1/2 Ton should have a unique to '39 transmission shift rod. Is this so? If so, is this readily available somewhere or do I have to have mine bent?
John Mc Crystal Lake, IL '39 1/2 Ton Pickup '56 Lincoln Capri Hardtop '77 Lincoln Town Coupe |
04-25-2011, 09:42 AM | #2 |
Re: Correct "swan" neck shifter rod?
John: On my 35 with 39 transmission we had to heat and bend the 39 shift lever to look like the swan and not hit the seat or dash. Looks close but not as nice as the 35. We chromed it after bending. Dave/Green Bay
04-25-2011, 09:50 AM | #3 |
Got this picture out of Mac Van Pelts book on Ford transmissions, he answers all questions in the book. Go to his web-site
www.vanpeltsales.com |
04-25-2011, 10:49 AM | #4 |
36-39 4 7/8" from the top of the pivot ball to the end. 32-35 4 1/8 there is a difference in the lever length.
1939 Fordor Deluxe 1939 Ford Coupe Std 1940 Ford pickup Nothing in life is to be feared; it is only to be understood. |
04-25-2011, 11:11 AM | #5 |
Thanks guys!
04-25-2011, 11:23 AM | #6 |
Of course, the million or so that were made, chances are there are still a few good ones left. Best of luck with your search. |
04-25-2011, 11:31 AM | #7 |
and they do make repops.....Mike
04-25-2011, 11:35 AM | #8 |
I like the double bend Ford shifter. It is all good.
I am a believer |
04-25-2011, 02:33 PM | #9 |
Hot Rod John on Flee-Pay sells the stainless steel unbent shift control. You bend it any way you want it. Being stainless, it will likely take a good bit of force to bend though. The stainless will polish like chrome without the corrosion problems.
Kerby |
04-25-2011, 04:02 PM | #10 |
I have bent several ( no heat ) with a pipe / conduit bender, sometimes called a "HICKIE " but if you want to come off at a close 90 at the shift tower, maybe some heat ?? to move the shifter closer to your leg or knee, its what feals right?? or thats why cowboys hats turn up on both sides, so you can get 4 people in the front seat of your pickup, think about it. ....OLD....BILL
