Old 09-19-2023, 10:20 AM   #1
Martinbuilt
Default Steering arm options
Hi.
I'm finally getting a chance to work on my steering and spindles.
This is the first time I've had it apart.
The balls on both sides are badly worn. I see that snyders has steering arms that have been renewed. Is this what most do? I like the idea of having reconditioned Ford parts over something brand new.
Thanks for any input.
Martinbuilt is offline   Reply With Quote
Old 09-19-2023, 11:06 AM   #2
J Franklin
J Franklin's Avatar
Default Re: Steering arm options
Buy them, they will make you happy.
Old 09-19-2023, 12:19 PM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Originally Posted by Martinbuilt View Post
Hi.
I actually machine the ball(s) from the studs and I install replacement balls onto that stud. As mentioned above, many do purchased restored steering arms from various vendors.
To my knowledge, no one is producing new steering arms, so you will be forced to restore your arms however might I suggest you consider purchasing one of the new Pitman Arms that is shorter than they were originally.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-19-2023, 01:12 PM   #4
Oldbluoval
Oldbluoval's Avatar
Just be sure they are done like Brent says
Others often drill ball and shank out and weld thru the remaining iron.
Greatly weakens the assembly. I’ve seen them fail.
Check with Bert’s and inquire as to procedures…I think they do them that way.
Oldbluoval is offline   Reply With Quote
Old 09-20-2023, 06:53 PM   #5
[email protected]
modela@aol.com's Avatar
Amen on seeing them fail. Had one that was powder coated and the ball with stem came totally off the arm. Back of the arm looked pristine with no sign of the failure or empty hole showing through the powder coat. Luckily it just happened in my own driveway and not at 50 mph away from home. Lucked out!
modela@aol.com is offline   Reply With Quote
