12-30-2018, 07:32 PM | #1 |
Johnson lifters, adjustrer torque
Installing a set of NOS Johnson adjustable lifters in the 59L block. Some of the adjuster bolts seem to be tighter than others. Is there a spec for the inch or foot lbs of torque they should at ? Thank you Fordbarners.
12-30-2018, 08:46 PM | #2 |
Re: Johnson lifters, adjustrer torque
60 inch lbs
12-30-2018, 11:23 PM | #3 |
run the bolt down and adjust on the way back out--they seem to get tighter that way???
12-31-2018, 07:23 AM | #4 |
Thank you. I found the same thing, they seem to get tighter the further you back them out. Another thing I saw was a quarter turn equals right about .010, which made it easy to prep them before installation. I measured the distance between the adjuster and the end of the valve, logged it for each marked lifter and valve, so I can adjust them fairly close to .012 & .014 before I install the valves and lifters.
12-31-2018, 08:23 AM | #5 |
your procedure is very close to what we do. I wonder if there is a "nub" under the bolt that spreads the bolt as it goes down??
12-31-2018, 09:39 AM | #6 | |
They can be tightened by squeezing the sections together.
12-31-2018, 10:15 AM | #7 |
Never thought of that, good idea. Thanks
12-31-2018, 10:28 AM | #8 |
X2 What Ron said. Learned some thing new. Thanks for posting that 51.
12-31-2018, 01:11 PM | #9 |
thanks 51-merc, knew something happened to make them tight
01-01-2019, 08:37 AM | #10 |
There is a good picture and description of the process for improving resistance of the lifter adjuster bolt in Vern's book on the flathead, page 148, figure 14
