04-10-2023, 07:33 PM | #1 |
Tailgate gasket help
Ok, time to get a gasket for the tail gate on my 57 wagon. There is what is left of the on the tailgate that I am trying to replicate. There is also a thin gasket on the body. So I am not sure if there is supposed to be two gaskets or the flat gasket is added on.
I have two samples from Steele that I am can use: 1) 7/16w X 1/2h 2) 1”w I can trim it down if need be X 5/8”h The second one pushes out just a smidge. So I think I can use the one gasket for both. Any ideas? Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
04-13-2023, 04:28 PM | #2 |
Re: Tailgate gasket help
my guess would be 1 gasket as far as the smush if it doesnt effect lining up the panel it may seal better
04-14-2023, 02:00 AM | #3 |
Mike. There is a post about this on the 57 Ford forum. I used two of the courier cargo door seals that DC sells.
Also I found that some people add a second rubber piece alpine the edge of the upper gate to get a better water deal. Also at the bottom edge there is rubber flap. My wagon is missing the holder metal for it so it doesn't have it right now. |
04-14-2023, 02:02 AM | #4 |
04-15-2023, 03:32 PM | #5 |
Thanks Abe, sometimes I forget where and when I post questions.
Mike
04-15-2023, 11:08 PM | #6 |
Since the original style for the gate corners doesn't exist, it's best to lure the extra water away from the gutter corners at the tail. |
