04-29-2016, 03:57 PM | #1 |
oil pan removal
Anyone out there experience trying to remove a oil pan while it is in the car and with all the bolts removed it will not come loose from the engine?
This particular pan is on a 51 EAB Flathead and is mounted in My 1940 DLX 2dr Sedan. It seems like someone has used some very high strength sealant on it. Any ideas on how to soften it up? Last edited by Gezer; 04-29-2016 at 07:18 PM. |
04-29-2016, 06:10 PM | #2 |
Re: oil pan removal
take a rubber mallet and whack the pan on the junction of the side and bottom.u can hit it pretty hard with no damage if careful.otherwise put a screwdriver in there and pound it in.carefully.it will come off take it slow
04-29-2016, 06:13 PM | #3 |
Re: oil pan removal
Hold on. I think 39 & 40s you need to lift the engine. Remove motor mounts.
I've never done it but this was what I was advised when I wanted to clean mine |
04-29-2016, 06:39 PM | #4 |
Re: oil pan removal
It is possible that the oil pan is somehow getting hung up on the crankshaft counter weights. Try turning the crankshaft ~1/4 turn/90° of one revolution and see if that will allow the pan to drop down.
04-29-2016, 10:46 PM | #5 |
Re: oil pan removal
Is it tight to the block or loose but you cannot completely remove it?
If tight to the block, insert a putty knife between the block and the pan Someone may have used a hardening sealer on an install in the past.
04-30-2016, 11:14 AM | #6 |
Re: oil pan removal
☆Edit: I must have glossed right over the part in post #1 about having a 51 engine in a 40 deluxe tudor, or that statement was added later by the OP. So, as Coopman mentioned in his later post, my comment above would apply to '48 (except for pu's) and earlier engines with 1/2 of bell housing cast onto back of block. The 8ba type engines, with separate bell housing, would not have these bolts coming down from the bell housing into the rear of the oil pan.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 05-07-2016 at 09:21 PM. |
04-30-2016, 12:38 PM | #7 | |
Re: oil pan removal
If it is just the sealant holding it on, get a utility knife and cut in from the side, between the block and the gasket. If it's really stuck you may need to cut out some of the gasket so you can get something stronger in to pry with.
'52 F-1, EAB flathead |
04-30-2016, 02:56 PM | #8 |
Re: oil pan removal
This is correct for removing the pan but it appears he needs to loosen it from the engine first. This is a tough job. Given a choice, I would rather clean portable toilets with a sponge.
04-30-2016, 03:18 PM | #9 | |
Re: oil pan removal
05-03-2016, 09:07 PM | #10 |
Re: oil pan removal
If you were going to spray something on to the pan/gasket area to soften and help release it, what would it be?
05-04-2016, 07:36 AM | #11 |
Re: oil pan removal
The engine has to be raised about 2 1/2"s in the front and the
front counter weights on the crankshaft have to be down. G.M.
www.fordcollector.com |
05-04-2016, 09:11 AM | #12 |
Re: oil pan removal
Gezer: What type of oil pan do you have on your 51 engine
Is it rear sump or something else? |
05-07-2016, 11:54 AM | #13 |
Re: oil pan removal
Well guys, after beating and prying, I finally got the oil pan to drop off of the engine. But... it will only fall about 1/2 inch. The front lip of the pan hits the front cross member.
The pan, again, is in a 40 sedan and is a 51EAB engine. It is a rear sump pan. As GM stated, It seams like I need to raise the front of the engine. GM do you have in mind a step by step process for doing that? |
05-07-2016, 12:05 PM | #14 | |
Re: oil pan removal
05-07-2016, 01:24 PM | #15 |
Re: oil pan removal
Gezer: Just for the heck of it, along with raising the engine, try rotating the crank (manually) so that the "throws" of the crank are facing upward so as to provide more clearance for pan removal. I remember reading that this has to be done on the early V-8s.
08-25-2016, 03:22 PM | #16 | |
Re: oil pan removal
How have you accomplished doing that since the starter has been removed? How did you turn the crank and what indicates that the throws are in the up position? |
08-25-2016, 03:37 PM | #17 |
Re: oil pan removal
I turned mine with a long ratchet and socket on the crankshaft bolt, you will have to turn it a little and wiggle the pan.
08-25-2016, 03:48 PM | #18 |
Re: oil pan removal
Wow, not to be critcal, just curious, you originally started working on this about four months ago. Did you get sidetracked or have you been struggling with this all that time? Again, just curious.
This is a big reason why I personally favor pulling the engine out to remove the pan or install a new clutch, since it's usually something wrong that is much easier to cope with when the engine is out and on a stand. JMO
08-25-2016, 07:24 PM | #19 |
Re: oil pan removal
I have not long removed my pan in place ended up taking the radiator out front grille then with a chain block lifted the engine several inches and as far forward as possible yes the pan does hit the front crossmember by wriggling the pan on an angle to the left got it out it also fouled on the oil pump pickup it's a mission in place needed new engine mounts anyhow hope you have it out by now!
08-26-2016, 09:12 AM | #20 |
Re: oil pan removal
Thanks for your input.
You are also right about ,"it's been a long time". Other things have taken priority. I will try the socket on the crank. If that does not work I will pull the engine. I assume that you can determine where the crank is by looking in one of the front spark plug holes. |
