Old 01-25-2017, 09:01 AM   #1
Vanspeed
Vanspeed's Avatar
Default C-4 pan fill dipstick problems
Hi guys, I am putting a '71 302 and this C-4 in my '53 F-100. I have an issue with my trans dipstick. It is exactly in the way of the exhaust manifold. I have not seen a dipstick like this one. Others I have seen are closer to the block. What is this from? Can I source a correct tube that will miss my exhaust?
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 01-25-2017, 09:49 AM   #2
Ole Don
Ole Don's Avatar
Default Re: C-4 pan fill dipstick problems
Two easy ways to get around your problem. Seek a pair of exhaust manifolds from a 351 passenger car. They bolt on your motor and are like cast headers. Then buy a 351 passenger Y pipe, and cut and weld it to your specs.
Two; heat and bend the tube to clear the exhaust you have, and shorten the brace.
Ole Don is offline   Reply With Quote
Old 01-25-2017, 09:56 AM   #3
okiedokie
okiedokie's Avatar
I am with Ole Don, I have done the heat and bend along with bending /shortening the brace.
okiedokie is offline   Reply With Quote
Old 01-25-2017, 10:27 PM   #4
packrat5
As Mr. Plumber says, aftermarket flexible dipstick tube.
packrat5 is offline   Reply With Quote
Old 01-25-2017, 10:32 PM   #5
2345.coupe
2345.coupe's Avatar
Originally Posted by joe plumber View Post
I have a Lokar dipstick in my 55 f100 with a c-4 transmission.
yes sir, as was said....lokar flexible dipstick
2345.coupe is offline   Reply With Quote
Old 01-25-2017, 11:13 PM   #6
Vanspeed
Vanspeed's Avatar
Nah, no aftermarket stuff for me. Heated it at the bottom a little and bent it towards the trans then cut the top and rotated it 180 degrees. Looks like it will work just fine and it cost me nothing. Original question though, pan fills must have used a different manifold??
Old 01-26-2017, 10:26 AM   #7
Ole Don
Ole Don's Avatar
Each design had different dimensions. The parts you have did not match when new, and they don't match now. You did a masterful job of making it better.
Old 01-27-2017, 11:24 PM   #8
Keystone 34 3w
Keystone 34 3w's Avatar
The trans is from a truck or the big car line. The exhaust manifold is from a car with the smaller case filled C-4 where the dipstick tube hugs the bell-housing. I'm glad you found a way around it.
Keystone 34 3w is offline   Reply With Quote
Old 01-28-2017, 10:57 AM   #9
5851a
Exactly what he says and a nice job forming that tube.
5851a is offline   Reply With Quote
Old 03-03-2017, 08:52 PM   #10
Vanspeed
Vanspeed's Avatar
The engine came out of a 1971 bronco with only 50k miles. It was the original engine to the bronco as it was owned by a fire department. It was a manual trans originally.
Old 03-03-2017, 10:22 PM   #11
paul2748
paul2748's Avatar
When I replaced the Fordo with a C4 the tube hit the valve cover. I little heat bn the tube to bend it and it was ok.
48 Ford Conv
56 Tbird
54 Ford Victoria
