Old 05-28-2011, 10:12 PM   #1
Digger
Digger's Avatar
Default Backfire causes?
Got the stock 39 to run. Let or run for about 20 minutes, it could turn off and then start again no problem. Then while revving up the motor, got a huge backfire, and now it won't start again. What would cause it and any solution suggestions?
Digger is offline   Reply With Quote
Old 05-28-2011, 10:27 PM   #2
Russ/40
Russ/40's Avatar
Default Re: Backfire causes?
If you had a 94 carb on it, you have blown the power valve. Its probably flooding now. Don't rule out ignition also. Check for spark, if it's there, go on to replace the power valve.
Russ/40 is offline   Reply With Quote
Old 05-28-2011, 10:58 PM   #3
Digger
Digger's Avatar
On the ignition side, what could have gonevout? Like the points frying?
Old 05-28-2011, 11:34 PM   #4
quickchange34
quickchange34's Avatar
Check and see if you have spark first, if you do, then you have lean condition cause by gas not getting to the carb like it should. Out of gas ,block fuel line, bad pump, needle and seat stuck.
quickchange34 is offline   Reply With Quote
Old 05-28-2011, 11:48 PM   #5
Digger
Digger's Avatar
Before this happened, I put in fresh points and condenser. The carb is a Stromberg EBU that was just rebuilt by Mike Hubbard. So now will go back and do whatever need it over again.
Old 05-29-2011, 12:37 AM   #6
FlatheadTed
FlatheadTed's Avatar
Its a posable a bad connection to points or condensers or bad condenser .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 05-29-2011, 03:21 AM   #7
ken ct
There is no such carb as a strom EBU. you must mean a ford-holley ebu from a 53-54 ford.Like someone said you most likely blew the power valve. I would replace with a #5.5 one,you would also need a few gaskets. OMO ken ct. This is also not the carb to use on a 59AB engine.This is a loadamatic carb.Has vacume provision on the rear of it.No need for it. Use a #59 carb. Could be a vacume problem or timeing problem.
ken ct is offline   Reply With Quote
Old 05-29-2011, 11:11 AM   #8
Russ/40
Russ/40's Avatar
I've seen the same problem, when the ignition connection at the switch was not good. Intermittent ignition will cause huge muffler explosions, sometimes misinterpreted as backfires.
Old 05-29-2011, 01:26 PM   #9
stromberg81
stromberg81's Avatar
Was the back fire through the carb or exhaust??????????/
Duane.
..Commitment is a 100%..
stromberg81 is offline   Reply With Quote
Old 05-29-2011, 06:25 PM   #10
Digger
Digger's Avatar
Exhaust....
Old 05-30-2011, 11:52 AM   #11
stromberg81
I think I'm right, through the exhaust is ignition and through the carb is fuel?????
Duane.
Old 05-30-2011, 12:00 PM   #12
Old Redneck
Old Redneck's Avatar
Send a message via AIM to Old Redneck Send a message via Yahoo to Old Redneck
If the points are set too close it will backfire also. Wouldn't take much to straighten that car out.
Old Redneck is offline   Reply With Quote
Old 05-30-2011, 03:05 PM   #13
bobH
Another thing I don't see mentioned.... Do a close inspection of the distributor cap. Look for carbon tracks between terminals. On my own car (crab distributor), I recently had a similar situation - substantial 'firings' in the exhaust. What I found was a carbon track between #6 & 8. A new cap fixed it.
bobH is offline   Reply With Quote
Old 05-30-2011, 03:27 PM   #14
FlatheadTed
also manifold leak and carby
