09-02-2018, 07:37 AM | #1 |
2 tooth sterering box
So I'm trying to put one of these steering boxes together using Les Andrews' book as a guide. I say "AS A GUIDE" only because I have to wonder if this guy has ever seen a RHD sterring box. He talks of the Steering shaft end play adjusting bolt being on top of he box. It is on the side. He talks of 3 turns lock to lock. It is 2 3/4. There is more too. We all know there are errors in his book so maybe I'm missing something. That's why I'm now turning to the store of knowledge here on the forum.
What I have now is when I put the sector shaft and its housing on the steering box, the steering shaft is locked. I've tried all of the adjustments and got some improvement but when I adjust the accentric nut to remove play in the pitman arm, the shaft is locked after I do up the nut on the sector housing. If I back off the accentric enough to allow the shaft to move, I have about 4 inches freeplay in the steerijng wheel (yet none in the pitman arm.) There is no end play in the steering shaft and none in the sector shaft. I've tried palying with the centralisation rivet but there is no imporovement. Does anybody have a suggestion to help me get this gizmo right? Anybody with experience with RHD 2 tooth steering boxes?
09-02-2018, 12:10 PM | #2 |
Re: 2 tooth sterering box
If your worm and sector are new, it should adjust. If old and worn, that is your problem. We have all been right where you are today. Even when you get it adjusted good, when you tighten the cover bolts, it will become tight and start to squawk when you load it up. It is a cut and try situation. Good luck.
09-02-2018, 01:49 PM | #3 | |
09-02-2018, 02:48 PM | #4 |
I found the service bulletins easier to use than Les's book.
John |
09-02-2018, 04:31 PM | #5 |
I should have mentioned that the worm and sector are new. Cold here this morning so I'll be in the workshop hopefully not getting even more frustrated.
09-02-2018, 06:10 PM | #6 |
09-02-2018, 06:21 PM | #7 |
Thanks. I thought of that but I got the bare housing for this steering box from a deceased estate so I have no original innards.
09-02-2018, 10:50 PM | #8 |
Arnold, Just put two together with all new parts. No problems apart from the cost,
There was some faulty sectors available few years back, Mainly when you fitted the drop arm too the sector shaft the drop arm at the ball end was 1" out hence non free play was not in straight ahead position ,there was two suppliers of them ,Not your problem ,Are you adjusting correctly, ie final adjustment must be in clockwise direction, Better send it to me ??? Cheers Derek |
09-03-2018, 04:56 AM | #9 |
I'd be interested to see a photo of the box. My 29 version seems to have 32 inards with the 32 pitman arm with the replacable ball.
I think the Australian service bulletins use LHD diagrams. (can't check at the moment) |
09-03-2018, 05:23 AM | #10 | |
09-03-2018, 11:05 AM | #11 | |
1" is pretty good but more adjustment may reduce it a little when done on the work bench. Also, use 250 wt or thicker oil if you can get it. Some like corn head grease which thins out when warm, etc.. |
09-03-2018, 12:43 PM | #12 |
Almost every time I had problems like this with a two-tooth box, it turned out the large rivet at the bottom of the housing needed more tweaking. A little twist in either direction makes a big difference. This adjustment isn't so critical with used gears still in the car and worn in against each other, but it is very important when installing a new worm and sector. The lash in either direction MUST be equal in order to get the mesh correct between the two. If this is off, the adjustment with the large eccentric nut will become very frustrating, if not impossible to get down to a minimal free play at dead center. Use a dial indicator if possible to determine equal movement for this fourth adjustment - then go back and perform the standard three adjustments. Of course, this is MUCH easier to perform with the steering column out of the car and secured in a vise.
Marshall |
09-03-2018, 02:47 PM | #13 |
Rhd and Lhd adjust just same as they are a mirror image of each other .Some Rhd boxes do have the shaft bearing endplay nut/bolt on the side instead of the top,maybe this is a Ford or Gemmer thing maybe I will look into that.
John in lovely weather today Suffolk County England . |
09-03-2018, 07:16 PM | #14 | |
09-03-2018, 07:37 PM | #15 |
No turn it clockwise unless your aussie clocks turn counter clockwise ?? just kidding
09-04-2018, 08:29 AM | #16 |
Arnold, there were two different 2 tooth steering boxes for Right Hand Drive. The early one had the adjustment on the top of the box - it was modified to the side shortly thereafter as the carburettor choke arm fouled on the adjustment bolt. It sounds like you have a bodgey made in Argentina sector and/or worm! Dave
09-04-2018, 02:44 PM | #17 |
My understanding is that all FOUR adjustments have to be made in sequence, again, and again, and again until it's right.
Paul in CT |
09-04-2018, 06:29 PM | #18 | |
09-06-2018, 01:12 AM | #19 |
At our Model A club meeting last night I was discussing this issue with one of the members. He has a similar oppinion of Les Andrews' books as I do (I'll leave it at that!). Seems the problem was that I followed his instructions and adjusted the sector shaft end play too early.
Today, I backed off the adjustment, then went through the rest of the process and once everything else was right, I adjusted the end play. I now have a steering box with virtually no free play and no bindiong anywhere. The only reason I am posting this follow up is for someone in the future who might find (need) this thread and to thank those who offered advice.
09-06-2018, 06:03 AM | #20 |
That's great. Let us know how it is when you put it in the car and down on it's wheels.
