05-09-2014, 06:43 PM | #1 |
53 Mercury
Will the dash come out the front? I have to rewire it and sure would be easier if it did. Thanks John
05-10-2014, 03:42 AM | #2 |
Re: 53 Mercury
Johnnydidd:
Who's wiring Harness are you using? I have a 53 Ford Mainline,Have asked on here who's harness to use got several good answers,( From HIGH $$$$ to buy rolls of wire ) THANKS BILL W |
05-10-2014, 08:40 AM | #3 |
Re: 53 Mercury
I dont know yet, I may do one wire at a time using rolls of wire. I know that on my 53 Victoria the gauges come out from the back. Hope since there is a cover on the front of gauges maybe gauges come out in the front. John
05-10-2014, 08:50 AM | #4 |
Re: 53 Mercury
John:
Either way Please report back the difficulty factor. I did the one wire at a time on a Mack truck after a small wire Fire. ( Thought it was small ) pulled one wire at a time / replaced Proud as a peacock when done ~~ Real neat job all brackets back in place / hear shrink tube installed. Hopped up in cab to start / NOTHING / Sat there for a moment trying to think where I went wrong. put my head on my closed fist , rested it on the center of the steering wheel ( YUP RIGHT WHERE THE HORN BUTTON WAS ) SCARED THE G~B's out of me as the darn truck started !!!!! |
05-10-2014, 09:41 AM | #5 |
Re: 53 Mercury
I done my 53 a while back, take the gauge pod off, used the one wire at a time way for the gauges, changed it to 12 volt with a Fords under dash reducer ( NAPA has them, they were used on Ford trucks for years, because they used 6 volt gauges)
STEVE1103 |
05-10-2014, 12:08 PM | #6 |
Re: 53 Mercury
Son, you will never blow an engine up in high gear. |
