Old 07-18-2013, 10:31 AM   #1
35 coupe
35 coupe's Avatar
Default 1948 rear brake adjustment
Posting for a friend, any suggestion for adjusting the lower plates on the rear or front 1948 sedan. could be late 48, no covers visible. Any diagrams would be great, he is having problems getting them adjusted properly.
35 coupe is offline   Reply With Quote
Old 07-18-2013, 12:52 PM   #2
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default Re: 1948 rear brake adjustment
The 46-48 didn't have the adjustment on the bottom like the 39-40, Just the 2 adjustment up higher on the backing plate. Just use an 11/16 wrench and pull down on both sides. Walt
Old 07-18-2013, 05:41 PM   #3
Old Henry
Old Henry's Avatar
Here are the instructions for adjusting the 46-48 brakes. No adjustments on the bottom - only the top.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
