Old 11-07-2012, 04:19 PM   #1
fred93
fred93's Avatar
Default 29 steering wheel fit
Do these pictures look right? There seems to be too much space between the steering wheel and the steering column???!! I don't have another 29 to compare so if someone could just let me know if it is right or not!!!
Also---look at the light switch rod that sticks out of the steering box--is that right--seems like it should come out more???
fred93 is offline   Reply With Quote
Old 11-07-2012, 07:32 PM   #2
Ford Doctor
Default Re: 29 steering wheel fit
I have checked my 29 and it does not have that much space between the wheel and column
Ford Doctor is offline   Reply With Quote
Old 11-07-2012, 08:41 PM   #3
fred93
fred93's Avatar
I don't know if it makes any difference but the steering box is a "Gemmer" which is a two tooth that was installed on some early 29's.
Old 11-07-2012, 08:54 PM   #4
glenn in camino
glenn in camino's Avatar
I'd also deepen the notches on your spark and throttle quadrant with a triangle file so the levers will stay put.
glenn in camino is offline   Reply With Quote
Old 11-07-2012, 11:02 PM   #5
columbiA
28-29 7-tooth steering box uses A-3616-B lite switch rod 45 3/4" long The 29 2-tooth Gemmer box uses A-3616-C lite switch rod 45" long.
columbiA is offline   Reply With Quote
Old 11-08-2012, 09:59 AM   #6
Smurkey
Smurkey's Avatar
Here's mine. As far as I know, original and unmolested (July 1929 build).
Smurkey is offline   Reply With Quote
Old 11-08-2012, 10:36 AM   #7
George
George's Avatar
That looks to be too much space. It probably has a 30-31 2 tooth steering shaft which is 1" longer than the 29 2 tooth steering shaft
George is offline   Reply With Quote
Old 11-08-2012, 11:50 AM   #8
TD
TD's Avatar
I agree - I have am original 29 and its much closer.
TD
TD is offline   Reply With Quote
Old 11-08-2012, 11:58 AM   #9
Jim/GA
Jim/GA's Avatar
Smurkey, to my uncalibrated eye, that wheel looks too high from the spark/throttle rods.
I don't have another '29 to compare to right now.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 11-08-2012, 11:59 AM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
The steering wheel hub on my 9-27-28 with 7 tooth steering is about 1/16" to 1/8" from the steering column bushing. It's never been apart.
I'll go out and look at my 2-23-29 Tudor with 2 tooth steering.
My 29 is the same as my 28, about 1/16" between the steering wheel hub and the column bushing.
Old 11-08-2012, 05:06 PM   #11
Smurkey
Smurkey's Avatar
Well so much for unmolested...guess it was molested somewhere in the past. Good thing though, I need every inch I can get that wheel up.
Old 11-09-2012, 09:26 PM   #12
fred93
fred93's Avatar
This picture is your assembly and it sticks out of the column housing THAT far??
Old 11-09-2012, 09:37 PM   #13
fred93
fred93's Avatar
So why is my steering wheel hub to column bushing so much?? Is there some thing that I can adjust?? Or do I just need to take everything apart and start measuring the column--shaft--etc???
Old 11-09-2012, 10:31 PM   #14
columbiA
Fred93 I think your worm shaft is about 1" to long.In feb 1930,the worm shaft in the 2-tooth box was made 1" longer.The shaft in the 29 & early 30 Gemmer box was shorter & required light switch rod A-3616-C for a 1930 model.I think someone in the past had installed the later shaft in the early Gemmer box.Pages 481 & 517 of the Service Bulletins has info on changes in worm brgs.
Old 11-09-2012, 10:41 PM   #15
columbiA
In post #14,the 29 Gemmer box required light switch rod A-3616-C & the early 30 Gemmer box requires LS rod A 3616-G.Should have proof read it beforehand.
Old 11-10-2012, 01:39 PM   #16
fred93
fred93's Avatar
Thanks for the info---I will be tearing the assembly down soon and I will check all the parts for correctness and proper measurements.
Thanks again to all!!
