09-10-2022, 05:37 PM | #1 |
10" clutch ID?
Recently removed this plate from the back of a 59AB.
The flywheel appears to be stock. There are no extra holes drilled / tapped for this bolt pattern. I can no longer recall how many clutch R&R's I've done. I'll state "many". I have never seen this bolt pattern / pressure plate. The six holes are evenly spaced. Center to center is about 5 3/4". So, any idea what I have here? thanks...
09-10-2022, 06:09 PM | #2 |
Re: 10" clutch ID?
'49 '50 Mercury pressure plate. 10" Borg & Beck.
Commonly seen on 8ba's in early Fords. Last edited by 42merc; 09-10-2022 at 06:16 PM. |
09-10-2022, 06:20 PM | #3 |
Re: 10" clutch ID?
It does appear to be a Borg and Beck pressure plate found on 8CM Mercury engines. The issue is that the 8BA/8CM flywheels aren't compatible with 59 styled crankshafts. I'd be interested in how that flywheel came to that engine.
09-10-2022, 06:35 PM | #4 |
Re: 10" clutch ID?
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 09-11-2022 at 01:15 AM. |
09-10-2022, 09:25 PM | #5 |
Re: 10" clutch ID?
The flywheel could have been drilled to take it. It uses the same spline as early Ford if it has the right number stamped in the periphery of the center port where the fingers are. The late 51 thru 53 Merc had longer fingers due to the use of the 1-inch 10-spline input. The 49 thru early 51 still had the 1 3/8" 10-spline same as early Ford. The later type Mercury transmission had the new gears and an all new bell housing plus a different throw out bearing for late 51. The Borg & Beck numbers are different for them.
Let me know what the numbers are and I can tell if it's Mercury 8CM stuff. I send mine to Fort Wayne Clutch to get them rebuilt. The numbers are in the Hollander Interchange manual. |
09-10-2022, 10:17 PM | #6 |
Re: 10" clutch ID?
09-10-2022, 10:18 PM | #7 | |
Re: 10" clutch ID?
Just to add... this was in a running, driving '36 for well over a decade.
09-11-2022, 01:16 AM | #8 | |
Re: 10" clutch ID?
The OP did not note whether or not this came off of a "Known-to-run-GOOD" engine. In other words, even though it was glued-together that way doesn't necessarily mean that it worked GOOD that way! Most folks know that you can swap a 4" Merc crank and rods into a "59" or earlier block, and it'll all work if you use a '48 and earlier flywheel. It's possible this guy didn't know about the differences between early and late flywheels and used the Merc flywheel & clutch 'cuz it was easy to glue-on, and 'cuz he had it laying there. Coop . Last edited by V8COOPMAN; 09-11-2022 at 03:46 AM. |
09-11-2022, 07:48 AM | #9 | |
Re: 10" clutch ID?
This vehicle has been operated just fine for at least the past dozen years. Crank? No idea what's in there.
09-11-2022, 08:17 AM | #10 |
Re: 10" clutch ID?
Just to add some more perspective. About the only issue I know of, is that when you use a late flywheel on an earlier engine the starter engagement can sometimes be a problem. Folks have mentioned that due to the ring-gear being in a different location, that this issue can happen . . . and I'm sure it has.
Personally, I've never had the problem and I run a Fidanza billet aluminum flywheel (49-53) on my 42 Merc engine. It seems that in the case of Kube, the later setup has been in the car for many years - without any issues. From a clutch and clutch-disc perspective, I can't see an issue. Whether it is a Borg and Beck clutch plate or a Ford Long plate really shouldn't make any difference. They both do the same thing and the throw-out bearing actuates them in the same manner. |
09-11-2022, 09:52 AM | #11 | |
Re: 10" clutch ID?
I won't be able to inspect this vehicle until this evening. I am very eager to look at it once again and eventually figure out exactly what I have here to work with. Thanks guys....
09-11-2022, 11:14 AM | #12 |
Re: 10" clutch ID?
Gentlemen,
Will this help clarify? https://www.jalopyjournal.com/forum/...lutch.1095611/ It looks like the same 50 Merc. 10 in. pressure plate and clutch I have installed on my 8BA using a 1950 Merc. flywheel. I used stock 40 Ford throw out bearing bearing with stock 40 transmission. |
09-12-2022, 12:55 PM | #13 |
Re: 10" clutch ID?
This is the place for clutch work.
https://kyclutch.com/ Fast, friendly, knowledgeable. They turned around a 41 Cadillac rebuild and balance in 2 days, $140, yeah shipping is $50 each way, but still 1/2 what others quote. The job was perfect, it never did better. |
09-12-2022, 02:04 PM | #14 | |
Re: 10" clutch ID?
KY Clutch and Performance, Inc. 250 Gun Club Road Brooks, KY 40109 (502) 955-9173 Hours of operation Monday-Friday: 7:30AM – 5:00PM (EDT) Saturday: 9:00AM – 12:00PM (EDT) Payment Methods We accept VISA and Mastercard Looking for a clutch kit? Need a rebuild? You're in the right place. Whatever you're looking for, we have it in stock.
09-13-2022, 09:24 AM | #15 | |
Re: 10" clutch ID?
Thanks to all!
09-13-2022, 11:50 AM | #16 |
Re: 10" clutch ID?
This is a similar place, small shop, good service. They rebuild your parts. The clutch Doctor. https://www.chamberofcommerce.com/un...-clutch-doctor
