04-18-2019, 02:01 PM | #1 |
Starter issues
Good day,
Got the car started today 1930 ford however ...it stopped attempts to restart a than just heard a grind noise when I press on the starter any ideas what’s going on? |
04-18-2019, 02:38 PM | #2 |
Re: Starter issues
Was it turning the engine or just making noise?
04-18-2019, 06:40 PM | #3 |
Re: Starter issues
Put the car in third gear and rock it back and forth. If you hear it pop loose it may be a bad spot on the ring gear. Just a thought??? Chap
04-19-2019, 12:18 PM | #4 |
Re: Starter issues
Could be the bendix spring has broken, or the bolt holding it has broken. Not a hard job to remove the starter to inspect the situation.
04-20-2019, 08:35 AM | #5 |
Re: Starter issues
Well when I pushed the the starter i suspect it was turning the gear...don’t think the starter was doing anything
04-20-2019, 08:37 AM | #6 |
Re: Starter issues
04-20-2019, 08:37 AM | #7 |
Re: Starter issues
Got it out need to trouble shoot
04-21-2019, 05:47 PM | #8 |
Re: Starter issues
Thanks
