11-28-2015, 08:32 AM | #1 |
water outlet problem.
This might be a dumb question but I don't seem to be able to stop water from leaking from the water outlet on to of the head. Yesterday I broke the outlet casting trying to tighten and upon removal the gasket seemed to be blown out on one side. Should I be using more than one gasket? also I see the vendors sell a copper gasket for show cars, although I'm building this as a daily driver, should I switch to that gasket over the paper ones? All help appreciated. Harv
11-28-2015, 08:38 AM | #2 |
Re: water outlet problem.
Many people use no gasket, but make sure the outlet mounting surface is dead on flat, then use a bit of sealer on the mating surface.
Never use a paper gasket, as they get wet and squeeze out of place, and that's when you crack the casting. |
11-28-2015, 08:40 AM | #3 |
Thanks Tom, that's the route I'll go. Harv.
11-28-2015, 08:43 AM | #4 |
two ways to go no gasket with rtv or a copper gasket. paper is a no-no
surfaces need to be flat i have never had an issue using the copper gaskets I also use them on my cars cause it looks better Last edited by Mitch//pa; 11-28-2015 at 10:26 AM. |
11-28-2015, 08:49 AM | #5 |
Think I'll buy a copper gasket as a back up. Harv.
11-28-2015, 09:13 AM | #6 |
11-28-2015, 09:56 AM | #7 |
I've also never had a problem using a copper gasket, and use one on my car.
I think the paper gaskets are sold to increase sales of new water outlets. |
11-28-2015, 10:31 AM | #8 |
Tom, do you use gasket sealer with the copper gasket? Harv.
11-28-2015, 10:57 AM | #9 |
I'm not Tom but I don't and try to avoid it whenever possible
11-28-2015, 11:00 AM | #10 |
Thanks all, copper gasket it is. Harv.
11-28-2015, 01:59 PM | #11 |
I like the orange Permatex sealer with or without a thin gasket.
(There is no such thing as a dumb question) |
11-28-2015, 10:12 PM | #12 |
I've broken ears torqueing with thick copper gaskets but never with no gasket. I file flat and use a thin film of Permatex.
11-28-2015, 11:47 PM | #13 |
This is what I use, without a gasket. Pretty hard to break this one if at all.
11-29-2015, 02:53 PM | #14 |
Chief taught me how to cut gaskets, with a small ball pein hammer, with a tap-tap-tap-tap. Minerva sported a Bill, special, gasket, cut from a brown paper bag, a careful smear of BLACK RTV, on both sides, & NEVER broke the neck or LEAKED, so THERE! "Maybe" a good subject for "MYTH-BUSTERS"??
Bill W.
11-29-2015, 03:08 PM | #15 |
11-29-2015, 03:40 PM | #16 | |
Last edited by Y-Blockhead; 11-29-2015 at 03:50 PM. Reason: Add link... and correct spellin' |
11-29-2015, 05:48 PM | #17 |
Thanks Y-Blockhead
11-29-2015, 06:23 PM | #18 | ||
11-30-2015, 04:00 PM | #19 | |
Bill W.
11-30-2015, 04:21 PM | #20 |
Just use RTV on my installs. Haven't cracked a neck since.
Oklahoma City Model A Restorers Group. |
