Old 07-29-2011, 06:07 AM   #1
timcv
Default tea pot carbs
I'm running a ford y block with 2 - 4 barrel tea pot carbs and mallary distr. getting ready to try and fire it up for the first time. anyone used this combo before? heard good and bad about tea pot carbs. thanks, tim
timcv is offline   Reply With Quote
Old 07-29-2011, 06:27 AM   #2
ken ct
Default Re: tea pot carbs
I vote bad. They were called "TOWERING INFERNOS" back in the days. OMO. "Kens Ford Carbs" ken ct.
ken ct is offline   Reply With Quote
Old 07-29-2011, 08:16 AM   #3
Merc Cruzer
Merc Cruzer's Avatar
53' Merc 2bbl: The carburetor is very basic and gets poor gas millage, but I have found that if you assemble them then correctly (very tight) they do not leak. I due note that the mechanical fuel pump will not keep up with mine so I use a back up electric during heavy acceleration.
Merc Cruzer is offline   Reply With Quote
Old 07-29-2011, 10:31 AM   #4
Oldmics
Tim
There were only 3 sets of "LIST" numbers for the correct Ford dual quad carburators.
Can you enlighten us as to what "LIST" numbers are stamped on the base of your carburators.
I have a correct dual quad setup on my 56 T Bird. It runs great!
Oldmics
Oldmics is offline   Reply With Quote
Old 07-29-2011, 10:37 AM   #5
darrell
i never found these carbs hard on fuel.they were nice working carbs when in good condition.
darrell is offline   Reply With Quote
Old 07-29-2011, 04:19 PM   #6
46yblock
46yblock's Avatar
I am looking forward to using a T pot on my 272. Carb is done, engine is still unknown.
I think their bad reputation is probably undeserved. A retired mechanic friend, 78 years old and still wrenching out of his garage, likes them. And he is a Chevy guy!
Post the List numbers so Oldmics can tell if they are a matched pair.
Mike, S. Oregon 46 Ford 1/2 ton, '62 Merc Meteor S33, '54 Ford 600 tractor, '64 Falcon Futura, 1960 Thunderbird
46yblock is offline   Reply With Quote
Old 07-29-2011, 08:28 PM   #7
Kahuna
Kahuna's Avatar
I have been running a teapot 4 bbl carb for the last 21 years without problems.
Kahuna is offline   Reply With Quote
Old 07-29-2011, 09:31 PM   #8
paul2748
paul2748's Avatar
I have a tea pot on my 56 TBird and it runs good. Depends on who rebuilds it. I hear lots of bad stories about Pony
Old 07-30-2011, 05:13 AM   #9
timcv
Thanks for the responce! Carbs are installed with linkage and fuel lines so #'s hard to see. My best guess
edk 9510 11 list 1074
hope to fire them up this morning. Wish me luck! Thanks again fellas timcv
Old 07-30-2011, 06:44 AM   #10
Ole Don
Ole Don's Avatar
Please tell us more about the engine and the car it will be in. Isnt this the set up used by Carrol Miller in the 56 at Bonneville all those years ago?
Ole Don is offline   Reply With Quote
Old 07-30-2011, 07:31 AM   #11
timcv
292 Y block bored over and camed with high compression t bird heads 2-quads with mallory distr. manifold and carbs off t bird (so says the guy i bought them from) would like to use the old carbs if i can make them work. they're kool lookin
Old 07-30-2011, 09:43 AM   #12
Merc Cruzer
timcv:
Poor choice of words: hope to fire them up this morning. Wish me luck.
Remember I am a believer in the Teapot...just trying to figure how to get better mileage out of it.
Old 08-09-2011, 11:38 AM   #13
Ray With
Ray With's Avatar
T pots are ok but better preformance would be using the old cad rochesters. In 56 my 292 ran better with the cad carbs but all the time I had used the T post I had no problems .
Hotrodchat's Picture Gallery
26,000 pictures to keep you looking
Ray With is offline   Reply With Quote
Old 08-09-2011, 12:59 PM   #14
46yblock
46yblock's Avatar
Being totally unfamiliar with Rochesters, what model if any would be a good choice for my '55 272 with 4V intake of the same year?
Old 08-09-2011, 09:21 PM   #15
parklane
parklane's Avatar
If you can find a GM car with about the same size engine, it should be a done deal.
If brains were wire, some couldn't short circuit a firefly
parklane is offline   Reply With Quote
Old 08-10-2011, 07:52 AM   #16
Bill Steiner
The so called T pot carb works good if rebuilt correctly. Not hi performance but will run good. I have rebuilt many of them in the last 50 years. Bill S.
Bill Steiner is offline   Reply With Quote
Old 08-17-2011, 08:59 PM   #17
Ray With
Ray With's Avatar
I used the one on 54 or 55 cad--olds and they worked well and were factory units. I did rejet as necessary
Old 08-22-2011, 07:28 PM   #18
zoegrant
zoegrant's Avatar
I have a teapot on my 56 which has been rebuilt by "MIKE SUTER in PENNDRL,PA" and it runs excellent ...right out of the box and on to the manifold with no adjustments..He test them on his engine stand before returning them to you...If you need his address, email me...John in CT
zoegrant is offline   Reply With Quote
Old 11-22-2011, 01:15 PM   #19
Dutchtreat
Dutchtreat's Avatar
Ok Guys I am a a ford guy and have heard of the Teapot. But that said who made them and are they the same size as a Carter WCFB?
1st. Cav Trooper
Operation Garry Owen
F Troop 9th Cav'71-'72
Dutchtreat is offline   Reply With Quote
Old 11-22-2011, 05:16 PM   #20
Kahuna
Kahuna's Avatar
Holley made them. Std Holley jets work just fine. Similar in flow to the Carters
