Old 09-25-2015, 12:24 PM   #1
jwaldrich
jwaldrich's Avatar
Default Repair Of Electrical Short
After chasing a total dead short in a 1923 for a day and a half, I found a bad ground strap on the battery to the frame.
Replaced it and it worked great.
John from Kapowsin
T&A Guy
jwaldrich is offline   Reply With Quote
Old 09-25-2015, 04:55 PM   #2
Willie in Houston
Willie in Houston's Avatar
Default Re: Repair Of Electrical Short
Sounds like you had the opposite of a total dead short, you had an open circuit.
Willie in Houston is offline   Reply With Quote
Old 09-25-2015, 06:08 PM   #3
jwaldrich
jwaldrich's Avatar
However you want to word it (I'm not an electrician) I had no power anywhere except at the battery and the battery side of the starter switch..
John from Kapowsin
T&A Guy
Old 09-27-2015, 08:21 AM   #4
Royce P
Royce P's Avatar
Short circuit = connection when there is not supposed to be a connection.
Open circuit = no connection when there is supposed to be a connection.
1910 Touring
1914 Touring
1915 Touring
1917 Torpedo Runabout
Royce P is offline   Reply With Quote
Old 09-27-2015, 09:58 AM   #5
jwaldrich
jwaldrich's Avatar
Open circuit it is then. Thanks for the explanation.
John from Kapowsin
T&A Guy
