01-05-2011, 09:09 PM | #1 |
Which direction do you crank a flathead?
I have a stuck short block sitting on a dolly that I'm trying to free up. Read the earlier post of how to unstick a motor but in my case, does it matter which way I try to rotate the crank? I know that it would normally turn one way to run but being a short block does it matter?
01-05-2011, 09:16 PM | #2 |
Re: Which direction do you crank a flathead?
Clockwise when viewed from the front of the engine.
Don't never get rid of nuthin! |
01-05-2011, 09:20 PM | #3 |
Pull the cam gear & then you take the stuck valves out of the equation.
01-05-2011, 09:25 PM | #4 |
when trying to free a stuck engine it doesnt matter which way you turn it, you need to turn it both ways till it frees up anyway, lots of penetrate and patience is what is needed
01-05-2011, 09:29 PM | #5 |
Many thanks!
01-05-2011, 09:31 PM | #6 |
oops- wrong forum- thought i was on the 28-31
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. Last edited by sturgis 39; 01-05-2011 at 09:34 PM. Reason: apology |
