11-02-2014, 06:52 PM | #1 |
Running boards: 2 questions
I recently removed the running boards from my 39' DLX, scraped off the old, dried and broken rubber layer and now I need some help.
1. Referring to the attached photos, are these original boards or re-pops? These appear to have been hand fabricated by a highly skilled fabricator. Was this how they produced the originals in 39'? There is not a groove in the top of the board at the locations of the gross braces. I remember the original boards off of my 40' had this groove. 2. Are there recommendations as to the best supplier(s) of the new rubber covers? Thank you, Phil Last edited by 39topless; 01-23-2016 at 12:01 AM. |
11-02-2014, 07:07 PM | #2 |
Re: Running boards: 2 questions
I'm not expert on these parts, but they look like repros to me. I bought a pair for a 38 sedan several years ago that looked very similar.
11-02-2014, 07:10 PM | #3 |
The runningboards in your photos are Argentina MFG, sold by JC Witney in the 60's and 70's before the availability of US made covers for factory boards. The giveaway is the V shaped stiffeners. These boards looked OK back then, but were too short in the front and rear. I would not cover these aftermarket boards, the covers are made for genuine boards. Your 39 convertible deserves a set of Drakes repro complete boards.
11-02-2014, 07:20 PM | #4 |
Yep, now that I think about it that is where the ones I had came from!
11-02-2014, 08:07 PM | #5 | |
Anyone interested in a nice set of genuine, South American made, "muy hermoso" 39' Ford running boards? Realmente barato!. |
11-02-2014, 08:54 PM | #6 |
Drakes boards are okay as well. Much better than the Argentina boards but not as good as Ford OEM. I still prefer having Hunley vulcanize authentic boards for my projects.
11-02-2014, 09:13 PM | #7 |
I've used the Drake boards and the quality and fit is excellent. I've also used the boards that were covered by Hunley Acuff which are also excellent. With Acuff you will have to supply nice set of original boards for him to cover. Buying the Drake boards might be cheaper for you.
11-02-2014, 11:03 PM | #8 |
Just wondering for my own interest; are the repro's made from spring steel as the originals were.
11-03-2014, 08:25 AM | #9 |
No, they are not.
11-03-2014, 08:55 AM | #10 |
Fe26,I don't recall ever reading that running boards were made from spring steel. Where did you find that info? just curious.
11-03-2014, 09:23 AM | #11 |
There was a set of the boards made in Argentina on our '39 CS. I sent them to Huntley Acuff and he told me they would not stand up well under his process. He recommended the Drake boards. I had Drake send the boards to Huntley and he covered them. The fit of the Drake boards, with Huntley's rubber on them, is excellent! I would recommend using Drake's boards and having Huntley Acuff finish them.
11-03-2014, 04:13 PM | #12 |
I have a set of original, very straight '39 Deluxe or 1940 any model, boards that I want to sell.
Colorado is a long way to send them though. I'll run my original Fordbarn ad, back to the top. Thank you, MIKE (mikeburch) |
11-03-2014, 06:58 PM | #13 | |
When you think about how running boards were used back in the day it made sense to use spring steel. People used to ride along by standing on the running boards, I think they were used a lot more than we would use them now. |
11-03-2014, 09:44 PM | #14 |
Running boards are tough to straighten, but they may not necessarily be spring steel. The metal is fairly thick on the running boards, so they are not easy to straighten. I was just wanting to know where I could find the information regarding them being spring steel. I've never heard that before from anyone.
11-04-2014, 01:51 AM | #15 |
Now you've got me thinking...My belief was based on my perception of running board toughness/springiness nearly forty years ago. Now I think about it I am open to the idea a steel other than spring was used. My reasons are: (Although I have never done it I'm sure many people have welded/patched running boards.) Spring steel can't be welded. Also spring steel is more susceptible to corrosion than mild steel or medium carbon steel, and there are a lot of surviver running boards.
So, the options are; half hard medium/high carbon steel or manganese steel. Both of which would account for the higher than usual resistance encountered when straightening running boards. The data on this will exist somewhere, but in which archive... |
11-04-2014, 10:01 AM | #16 |
Fe26, I have seen running boards that were repaired by welding.
11-04-2014, 01:57 PM | #17 |
I replaced my originals (that had been recovered but were cut for muffler clearance!) for a set of Drakes New boards, easy to install and will not disapoint he may be having a sale soon
geoford41 |
01-14-2015, 10:22 PM | #18 |
OK!!!!!!! I went for the Bob Drake's and they are absolutely beautiful! Got in on the "Free Shipping" deal. Now. They are bare steel underneath. Would a coat of "out of the can" brush on bed liner be a wise choice or should I paint them with some good industrial enamel ?
Thanks, Phil |
01-15-2015, 10:05 AM | #19 |
Depending on what you want to do, you can buy the "rattle can" bed liner at Walmart and it gives a nice look underneath,
01-15-2015, 11:04 AM | #20 |
I would at least prime them before applying bed liner. Most liner products don't do much to arrest future corrosion. A good quality eching primer would work. Some primers are even black to boot.
