07-29-2014, 02:00 PM | #21 |
Re: Why don't some of the "High Rollers" mfg a good low pressure fuel pump???
Do any of the US manufacturers make anything similar the the SU pump used on jags and MGs etc?
I fitted one to my roadster as a priming pump and it works great. It offers no resistance to drawing fuel through by the mech pump and you know when the fuel has filled the carbs because it stops ticking. Mart. |
07-29-2014, 02:08 PM | #22 | |
07-29-2014, 02:17 PM | #23 |
If it's been sitting around for a while you might need to clean the contact points.
Mart. |
07-29-2014, 02:40 PM | #24 |
Been through that before. So far I haven't found new original style pumps available here.
07-31-2014, 12:01 AM | #25 | |||
No need for parallel fuel lines with the Airtex that allows the mechanical pump to pull through it when off. My 2¢
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
07-31-2014, 07:15 AM | #26 |
07-31-2014, 08:20 AM | #27 |
If the vapor lock is just preventing starting the pump should be able to be turned off as soon as it starts. If you have a regulator it's not so urgent to get it shut off. If not, the engine will start to stumble when the carb bowl overflows and starts flooding the engine or you smell gas flooding into the engine compartment. My vapor lock usually comes while driving and I have to keep the pump on for a while, especially if I'm climbing a mountain. Then it's on all the way up. I have a very small LED indicator light to remind me the pump is on.
07-31-2014, 08:42 PM | #28 |
Thank you. I appreciate the information.
