Old 05-10-2024, 11:25 AM   #1
Woodie1
Woodie1's Avatar
Default Engine dies
We have a 1939 Ford that dies when pulling out of our driveway. The incline of the drive to the road is not great but on first attempt the car dies. I don't know if I should blame the carb or fuel pump. The car is a rebuilt that I put on last year. The fuel pump is the one that came on the car when we got it 2 years ago.
Woodie1 is offline   Reply With Quote
Old 05-10-2024, 03:15 PM   #2
drolston
drolston's Avatar
Default Re: Engine dies
Is it correct to assume that before pulling out you have the engine warmed up? If you pull the choke out just a bit for fast idle, does it still die?
When exiting the driveway, is the front of the car uphill or downhill?
Old 05-10-2024, 03:34 PM   #3
Woodie1
Woodie1's Avatar
When I exit the drive I have the choke pushed in all the way. I probably only let it idle for a minute before leaving the drive. The car is headed up hill as it enters the road.
Old 05-10-2024, 05:13 PM   #4
drolston
drolston's Avatar
Try a bit more warming up and choke a bit for fast idle. If that does not take care of the problem we will need some more information. Like how easy does it restart after stalling? How does it run once you are on the road? Have you checked for vacume leaks, like the windshield wiper hose, etc?
Old 05-10-2024, 08:15 PM   #5
Woodie1
Woodie1's Avatar
It starts back up quite easily & runs fine. It can be a bit hard to start when it's been sitting for a week. I have not looked for vacuum leaks.
Old 05-10-2024, 09:13 PM   #6
JayChicago
JayChicago's Avatar
As already said, most engines want partial choke until warmed up. Don't push all the way in until after driving a bit.
Hard-to-start after sitting a week is normal. Gasoline evaporates out of the carburetor while sitting. Takes some cranking to re-fill the carb.
JayChicago is offline   Reply With Quote
Old 05-11-2024, 08:49 AM   #7
farmertom
farmertom's Avatar
Like Kube has said before, i too always pull choke all the way out after shutting down,to slow evap. Tom.
farmertom is offline   Reply With Quote
Old 05-11-2024, 02:08 PM   #8
Woodie1
Woodie1's Avatar
I think I had heard about pulling the choke out after shutting the car off. I tend to forget things these days. I'm still getting used to driving the car.
Old 05-11-2024, 03:47 PM   #9
JayChicago
JayChicago's Avatar
Isn’t the carb’s air vent opening above the choke plate, so a closed choke shouldn’t do much to stop evaporation? Or am I missing something else?
Old 05-11-2024, 06:34 PM   #10
farmertom
farmertom's Avatar
Kube suggested pulling choke out after puttin in the barn after ride.good enough for me. and i believe it works.not much effort,can't hurt. Tom.
