Old 08-06-2010, 10:23 AM   #1
Tom from Drippin'
Tom from Drippin''s Avatar
Default Marvelous Mystery Oil?
Some have reported adding to gas.
What is it suppose to do? And....how much in 10 gal. tank?
The pursuit of excellence is healthy and rewarding.
The pursuit of perfection is frustrating, neurotic and a terrible waste of time.
Tom from Drippin' is offline   Reply With Quote
Old 08-06-2010, 10:30 AM   #2
Logan
Logan's Avatar
Default Re: Marvelous Mystery Oil?
It lubricates the valve train better than just regular old engine oil will. it is suppose to make your valves last longer in the long run. Ive never heard of someone actually say a set amount to put in per gas fill up. But if i were to use it every time i filled up i would say roughly 6-8 fl oz. Its not to much, but its enough to lubricate.
Cowtown A's
Logan is offline   Reply With Quote
Old 08-06-2010, 11:10 AM   #3
Special Coupe Frank
Special Coupe Frank's Avatar
The container has recommendations for how much to add to the fuel tank ( believe it's on the order of 2 oz to 10 gallons Gasoline ).
Folks with Model L Gravely tractors swear by to prevent the exhaust valve from sticking open...
Never heard of it doing any harm.
I use it in my old iron; have never sprung for the "Marvel Inverse Oiler" ( or Ampco Cylidner Lubricator )... just add to fuel.
Special Coupe Frank is offline   Reply With Quote
Old 08-06-2010, 11:13 AM   #4
Mitch//pa
old school
Old 08-06-2010, 11:20 AM   #5
Russ/40
Russ/40's Avatar
It's a reasonable solution to the increase in alcohol in today's fuel. Prevents sticking valves. I ran an ampco oiler on one of my cars and enjoyed the dismay observers had when viewing the gadget under the hood. I would call it my "super sauce."
Old 08-06-2010, 11:26 AM   #6
Bruce Adams
Bruce Adams's Avatar
I believe the can says 4 oz to 10 gallons, which is what I do regularly.
Its like the glousamine I take for my arthritis.
You don't know if it works but everyone swears by it, and no one says its bad.
Bruce Adams is offline   Reply With Quote
Old 08-06-2010, 11:28 AM   #7
J Franklin
J Franklin's Avatar
4 oz. to 10 gallons gasoline, it is a top cylinder lubricant.
Old 08-06-2010, 11:33 AM   #8
Dave Pratt - IL
How big of a problem is sticking valves? I have 3 model A's. They are sometimes driven frequently and sometimes set for months. I have never had a valve stick just using 87 octane pump gas mostly with alcohol.
Dave
Dave Pratt - IL is offline   Reply With Quote
Old 08-06-2010, 11:36 AM   #9
J Franklin
J Franklin's Avatar
Oil also keeps things newer longer and has unstuck my valves when the engine was rebuilt.
Old 08-06-2010, 11:37 AM   #10
37 Coupe
37 Coupe's Avatar
I never used MMO or had a stuck valve in a flathead especially a rebuilt one until two years ago, the ethanol in the fuel must be the reason it is becoming more common now. Probably only had a couple hundred miles on 59AB engine and it ran fine in the morning going to local car show.After sitting all day with the hood up in about 90 degree weather it started and ran terrible driving home,missing and backfiring like the timing somehow was off. Remembered reading about this on the old Ford Barn and next morning tried the MMO down both sides of the carb with engine idling,took it down road and it cleared up and ran smooth after about a 1/2 mile. I put the prescribed 4 oz in 10 gallons every fillup now,I am a believer. Also I have heard that 10% ethanol is enough alcohol to contribute to tank or fuel line rust and in my mind the oil may help against this.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 08-06-2010, 11:41 AM   #11
Special Coupe Frank
I've heard about two issues with alcohol-blended fuels: one has to due with increased tendencies to turn to "varnish", the other is corrosion due to the water content of the alcohol...
Old 08-06-2010, 11:44 AM   #12
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
I ALWAYS add 4 oz to every fill up
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 08-06-2010, 02:06 PM   #13
billwill
check your plugs to make sure are not flowing.Itwill happen.
billwill is offline   Reply With Quote
Old 08-06-2010, 03:08 PM   #14
Jon
Jon's Avatar
OK, some one explain to me how it would lube the exhaust valves?? I'm not trying to be funny or step on someones toes, I've heard this all before and was just wondering how does the unburned oil in the fuel mixture get to the exhaust valves and do them any good?
John - Kalamazoo, MI
Jon is offline   Reply With Quote
Old 08-06-2010, 06:23 PM   #15
700rpm
700rpm's Avatar
I have found that 4 oz of MMO in a tank when I'm traveling in hot country or high altitudes helps eliminate the sputters and stutters. I don't know why.
Old 08-06-2010, 08:12 PM   #16
Ed Northrop
Ed Northrop's Avatar
The valves would stick and than make a pop sound, I started useing mmo and problem went away.
Ed Northrop is offline   Reply With Quote
Old 08-06-2010, 08:24 PM   #17
5window
5window's Avatar
Do a Google and there are Marvel Mystery Oil discussions on every kind of car forum you can imagine. Seems to be light weight oil, benzene, naptha,etc. Not really a mystery. here's a ink to the MSDS information with ingredients. Must be the wintergreen odor that makes it work.
http://www.turtlewax.com/res/msds/MM010-4.pdf
5window is offline   Reply With Quote
Old 08-06-2010, 10:41 PM   #18
Russ/40
Russ/40's Avatar
Dave
I think sticky valves can be more of a problem in fresh engines, than in high mileage engines. Tighter tolerances seem to be aggravated by the higher alcohol content fuels. We see the problem fairly frequently in the V8's. Much discussion on this issue on their forum.
Old 08-06-2010, 10:53 PM   #19
hardtimes
hardtimes's Avatar
Russ,
In all the discussion that you've encountered on this subject, have you heard any involving sticking valve...when stainless steel valves are used in an engine?
Old 08-06-2010, 11:10 PM   #20
Mike V. Florida
Mike V. Florida's Avatar
The exhaust travels past the valve stem on it's way out to the muffler. The oil coats the valve stem.
