Go Back   The Ford Barn > The Swap Meet > Wanted > Model-A
Old 11-21-2022, 01:45 AM   #1
1oldtimer
1oldtimer's Avatar
Default 1928 Tudor parts
City: Orange county
State: Ca.
Looking for a few 1928 parts,
*cast front seat hinges (upper and lower)
*Seat bar
PM me with what you have...Thanks.
Here's the '28 seat risers, notice the casting line on the side, the way the area is around the flat top and the angle around the bottom flat area. Should have an "M" cast in them or even a "Ford" script also.
1oldtimer is offline   Reply With Quote
Old 11-21-2022, 01:48 AM   #2
1oldtimer
1oldtimer's Avatar
Default Re: 1928 Tudor parts
Here's the 29-31 or 30-31 not 100% when these started and the other ended. I already have this type.
Has a distinct ring at the base above threads and the head is a machined flat spot.
Old 11-21-2022, 01:50 AM   #3
1oldtimer
1oldtimer's Avatar
Here's the '28 cast upper part of the seat hinge that is attached to the bottom of the seat. It's cast and has a stud that goes into the seat.
Old 11-21-2022, 01:54 AM   #4
1oldtimer
1oldtimer's Avatar
Lastly the seat bar. I think 30-31 had 2 cups, maybe 29 also??? under the seat as a stop for the floor. The 28 had a bar...
Old 12-05-2022, 01:01 AM   #5
1oldtimer
1oldtimer's Avatar
Bump.
Old 12-30-2022, 10:53 PM   #6
1oldtimer
1oldtimer's Avatar
Bttt
Old 02-26-2023, 04:37 AM   #7
1oldtimer
1oldtimer's Avatar
I need 1 more cast seat hinge and at least 1 seat bar.
Old 05-23-2023, 12:33 AM   #8
1oldtimer
1oldtimer's Avatar
Bump
Old 07-27-2023, 12:50 AM   #9
1oldtimer
1oldtimer's Avatar
Back up
Old 08-18-2023, 02:46 PM   #10
1oldtimer
1oldtimer's Avatar
Thanks to jw hash all I need now is the seat bar in post #4.
Old 09-15-2023, 08:18 PM   #11
1oldtimer
1oldtimer's Avatar
Seat Bar ?????
Old 11-18-2023, 12:59 AM   #12
1oldtimer
1oldtimer's Avatar
Bump for a seat bar.
Old 01-13-2024, 03:37 AM   #13
1oldtimer
1oldtimer's Avatar
I have everything on my list above EXCEPT a seat bar (pictured in the post above). I need at least one but will take 2 if you have them.
Need the seat bar ONLY, can't edit the older posts.
Thanks.
