03-09-2016, 03:29 PM | #1 |
32-41 Helmet Build from Bubbas
I get asked all the time , what do you guys do for a rebuild on the Helmet distributor???
Most of the time i dont have enough day left to tell ya the answer. Thats part of the reason for my new web site . Got one in today , nasty with broken ear. Gave it to Terry ( the master blaster) he got er cleaned up and i put it back together this afternoon. Take a look at the pics and ask all the questions ya want........ http://www.bubbasignition.com/32-41-helmet-build.html Just clic on the pictures and then right arrow thru them in large format..... |
03-09-2016, 03:36 PM | #2 |
Re: 32-41 Helmet Build from Bubbas
If you want it done correctly the first time send it to Bubba! (Jim Linder)
Mark |
03-09-2016, 03:56 PM | #3 |
Bubba you have a great web site. Very informative. I hope you keep up the service for as long as it's enjoyable for you three guys. Thanks for everything you have done for me over the years. I'm a very satisfied customer.
03-09-2016, 04:18 PM | #4 |
How did you fix the broken ear?
03-09-2016, 04:22 PM | #5 |
Bubba....I'm humbled by your expertise and craftsmanship....
03-09-2016, 04:35 PM | #6 |
16=Coil output testing , bright blue and spark jumps large gap and lights neon lamp!! Good coil Thanks for all you fellas do! And for the hot sauce!
03-09-2016, 05:45 PM | #7 |
Wow! That looks familiar. Just like the one that arrived on my front porch the other day. I've been keeping it on the coffee table for people to admire it. I can attest Bubba does nice work.
03-09-2016, 06:10 PM | #8 |
THREW IT IN THE TRASH AND REPLACED IT.... |
03-09-2016, 06:15 PM | #9 | |
Not only does it have a good spark gap it also has a loaded neon bulb. I let it run on the bench for some time. Seens to be really accurate as far as coil testing is concerned. |
03-10-2016, 11:54 AM | #10 |
Do you have a preference for a remote coil kit or a Skip rebuilt original coil? Why?
03-10-2016, 12:13 PM | #11 |
Can't wait to see it Jim! Yeah it was a little nasty but I knew you could do it!
Respecting and Resurrecting Ford Model A's. |
03-10-2016, 01:43 PM | #12 | |
The coil kits are of varieing quality, some good , some fair etc. But it also leaves the chance of the customer buying a very incorrect ignition coil. Customer will usually go a off shore poorly built chrome low resistance and then cause more problems than ever!!!!!! The story of my life !!! Wrong coil, wrong coil,wrong coil !!!!!!!!!!!!!!! |
03-10-2016, 08:38 PM | #13 |
I'll have to give Jim a little bit of praise. I sent him 2 Early distributors (a 1934 and a 1940). He rebuilt the 34 using the later 37-48 points and breaker plate. I took the car for a drive this week and ran perfect!
03-13-2016, 01:07 PM | #14 |
Bubba, at the bottom of your page http://www.bubbasignition.com/crab-42-48.html
Is this correct or around the wrong way ? I thought that turning inward retards the spark ? Note : Typically we ship the crab set at three turns inward on the spring for a light tension on advance ring. Ford suggests driving the vehicle with vacuum hooked up and turn inward until spark knock occurs on a slight load with throttle. Then back adjustment out until it stops. |
03-13-2016, 08:41 PM | #15 | |
Actually turning the adjustment changes the piston spring tension and the setting for the vacuum to allow spark retard... Good catch !!! Thanks .... |
