Old 08-21-2016, 11:25 AM   #1
TommyCoupe
TommyCoupe's Avatar
Default Weekend Warrior defeated
It's only noon here in CT, and already I've had my @$$ kicked by this car.
I've been having electrical/generator problems, which I though I had licked. Went out this morning and polarized the generator and started the car up. The ammeter may have moved a small amount when it was running, but if it did move, it was an insignificant amount. Revved the engine for a while and still no major movement.
Turned it off and measured battery voltage. 6.14v not running.
Started the engine again and voltage at the battery was 6.08.
The voltage at the cutout was 6.14. So my guess is that the generator isn't working.
Just before I shut the engine down again, I notice a lot of steam coming out of the overflow tube. So great, now I'm thinking I have a timing problem or carb problem, or who the h#!! knows. Probably someone on the barn would know, but today I'm just too stupid.
So, OK. Let's forget about that and move onto putting some glass in the car. I started on the passenger side quarter window. Just as put the last screw in, I hear a little snap sound, and a nice crack runs right down the middle of it.
Another lesson learned the hard way. I should start a thread listing all the things I have learned the hard way, so other people can learn from my stupidness. (Is that word ?)
So, OK. Let's just put it back in the garage. Got in the car, stepped on the starter button and the starter barely turns. I checked the battery voltage, and guess what. It was 6.14V.
Then after I struggle to push it into the garage (uphill by myself) it starts drizzling outside. The car kind of needed a cleaning anyway, but it just made it harder to get into the garage.
Finally got in the garage, and put the battery charger on it. Battery level looks low, but there aren't any meters on it or anything so I don't know what the real voltage is. It just says "charging 25%".
I'm going to go out and put the old 1970's SEARS charger on it and see what happens. I believe that one has an ammeter on it.
So, for today I am defeated. I won't get far on this car working just the weekends when things like this happens.
Ever have one of these days ?
Tommy-
TommyCoupe is offline   Reply With Quote
Old 08-21-2016, 11:51 AM   #2
William Kelchner
William Kelchner's Avatar
Default Re: Weekend Warrior defeated
Hang in there it gets worse. :) I spent the last several weeks trying to hook up the emergency brake to work on my car, it has hydraulic brakes and the emerg brake never worked, in fact it was not even connected. I finally won and I feel your pain. In my case I believe the score is 3 to 16 in favor of the car.... Cheers
William Kelchner is offline   Reply With Quote
Old 08-21-2016, 12:31 PM   #3
700rpm
700rpm's Avatar
Was that window plate glass?
Ray Horton, Portland, OR
Old 08-21-2016, 02:33 PM   #4
TommyCoupe
TommyCoupe's Avatar
No. Safety glass.
So I dug through my pile of old stuff and found the original piece of glass. Of course it has 50 year old primer on it, and was pitted a bit, but I cleaned it up and put it in. It looks OK for now, but I'll have to replace it before the interior goes in.
Old 08-21-2016, 03:59 PM   #5
mshmodela
mshmodela's Avatar
Tommy,
Sorry to read of your troubles... I'd take a few days break get some good sleep and think about what might be causeing your issues.. When my ass is kicked by a problem, I have to take a break or walk... You'll figure this out...
Best wishes.
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 08-21-2016, 11:29 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
Let's see;
Car off the voltage at the battery is 6.14.
Car running 6.08 at the battery.
Where are to measuring on the cut out? The output where the wires to the car are attached, has one wire that goes through the ammeter back to the battery so it should read the battery voltage. The other side of the cutout is the generator output. When the car is running if the voltage at this point is above the battery voltage the cut out is not closing.
I hope I have not confused you more.
Car off, generator side of cut out should read nothing. Output of cut out where the wires attach should read the same as the the reading of the battery.
Car on and at a fast idle, Generator side of cut out should
be above the battery voltage.
Old 08-22-2016, 12:37 AM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Mamma said there will be DAYS LIKE THAT, sorry you had one.
Problems always seem WORSE when it's your OWN car! It's like, MY car isn't supposed to BREAK! I just haul extra parts for OTHER people.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-22-2016, 03:53 AM   #8
cradlescyth
cradlescyth's Avatar
Welcom to the club !!!
cradlescyth is offline   Reply With Quote
Old 08-22-2016, 06:02 PM   #9
TommyCoupe
TommyCoupe's Avatar
Originally Posted by Mike V. Florida View Post
Let's see;
Charged the battery, and it now reads 6.22V with the engine off.
With the engine on, the battery is about the same. The cutout (where the yellow wire attaches) is the same as the battery. The opposite side of the cutout(where the post comes out of the gen) bounces around, but reads around 35V.
Is that right ???
Before doing all this, I pulled the generator out of the car and took the cutout off of it. Then with jumper cables I connected it to the battery, and the motor spun slowly. Then cleaned all the connections and put it back in.
Am I just wasting my time. In a few days I could have a brand new 6V Positive ground alternator delivered to my doorstep, and I think these troubles would go away.
Tommy-
Old 08-22-2016, 06:11 PM   #10
C26Pinelake
Should have had your wife push the car and you play flagman and direct het! Wayne
C26Pinelake is offline   Reply With Quote
Old 08-22-2016, 06:23 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
Looks like you have a bad cutout.
As soon as the engine starts jump across the two cutout terminals and read the voltage at fast idle.
Old 08-22-2016, 06:28 PM   #12
Willie Krash
Willie Krash's Avatar
Zen master says Model A will teach you patience and tolerance.
You are not alone.
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 08-22-2016, 11:12 PM   #13
Mike V. Florida
Tommy-
Learning is never a waste of time. If you want to get rid of that "clunker" I'll buy it.
Old 08-23-2016, 11:00 AM   #14
TommyCoupe
TommyCoupe's Avatar
It's a brand new Bert's cutout.
Tommy-
Old 08-23-2016, 11:35 AM   #15
tbirdtbird
new or one he rebuilt
'31 180A
tbirdtbird is offline   Reply With Quote
Old 08-23-2016, 11:52 AM   #16
Mitch//pa
Diode or contact style
Old 08-23-2016, 12:41 PM   #17
Tom Wesenberg
"Charged the battery, and it now reads 6.22V with the engine off.
Is that right ???"
Are you using a digital meter? If so, ditch it and use an analog meter, so you can get an accurate reading.
If the voltage is truly that high it indicates the current isn't being passed to the output side of the cutout. Start the engine and jump across the cutout terminals and see what the voltage reads.
Old 08-23-2016, 01:51 PM   #18
Mike V. Florida
Tommy-
Call him.
Old 08-23-2016, 10:38 PM   #19
Tom Wesenberg
Any chance the cutout is installed backwards?
Is your battery + ground?
Old 08-24-2016, 07:35 AM   #20
TommyCoupe
TommyCoupe's Avatar
Yes. The battery is positive ground.
When I called Bert's I asked for a restored original cutout, but I think it's a new one.
There is a picture of it in this thread. Post #23
https://www.fordbarn.com/forum/showth...=201118&page=2
I'll play around with it again tonight, and read the voltage across the cutout terminals.
Thanks Guys.
Tommy-
