Old 08-09-2011, 06:23 PM   #1
don's 37
don's 37's Avatar
Default Balancing Wide Five Wheels
I've went to two different auto repair shops to see if my wide fives can be balanced with no luck. Anyway to do this myself somehow? Any ideas? Thanks! Don
don's 37 is offline   Reply With Quote
Old 08-09-2011, 06:48 PM   #2
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: Balancing Wide Five Wheels
Some of the older shops have a adapter ring.
Speedway motors makes a adapter ring for a wheel change that works well when using a bubble balancer also. Thats what we have used for a while.........
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 08-09-2011, 07:49 PM   #3
T&A Dave
T&A Dave's Avatar
That is the same question I have been woundering for when I get tires for the '39. Thanks BUBBAS
T&A Dave is offline   Reply With Quote
Old 08-09-2011, 08:00 PM   #4
ford38v8
ford38v8's Avatar
Don, there was an adapter plate advertised in the V8 Times up until a year or so ago, cost I think about $60 or $70. The number's disconnected now. Forget about using a VW adapter plate, they won't fit. If you contract with a local machine shop to make a plate, you'll need to order a few extras to sell in order to recoup the investment. I got lucky with mine, as a member of my RG made several for the members.
Best bet is to check out the EFV8C Western New York Regional Group in Rochester. Go to a meeting and speak up. Someone there may have one you can beg borrow or steal. Call Frank Schiedt at (585) 637- 8863 and maybe he'll talk you into joining the RG. http://www.wnyrg.org/
Alan
ford38v8 is online now   Reply With Quote
Old 08-09-2011, 08:06 PM   #5
johnny
Have a machine shop machine the centre out of a disused drum,it will then mount to the balancer the wheel will bolt to the drum.PS make sure the machist balances the drum .John.
johnny is offline   Reply With Quote
Old 08-09-2011, 08:42 PM   #6
Lawson Cox
Lawson Cox's Avatar
Two suggestions. 1. Go to a place that can spin balance the wheels on the car. Probably a place that does medium size trucks. 2. Have the tire and drum balanced at the same time. Most any tire shop should be able to do this. I have had it done both ways.
Old 08-09-2011, 09:22 PM   #7
sturgis 39
Everything changes in this world. Change is the only thing a person can rely on. Look how tire sizes have changed over the years. I think some new cars are running 20 inch tires. They will bring the wide fives back again for some marketing reason. I love wide fives. In the sixties you had to have 15 inch wheels with all sorts of fancy white side walls. Now you have to have 16 inch wheels with wide white walls. I hope they do not start making fake white side walls again. The kind that are a white ring that go into the tire rim bead. I remember when you had to run red wheels and no hub caps no matter what color the car was painted. Then you had to run black wheels with black wall tires. I think hot rodders and street rodders are a bunch of conformists.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED
Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread.
sturgis 39 is offline   Reply With Quote
Old 08-10-2011, 12:54 AM   #8
ken ct
Find the oldest front end shop in the area and some usta have a balencer that does them on the car.Looks like an uprite house vacume cleaner and works great.Has a motor in it that spins the wheel.ken ct.
ken ct is offline   Reply With Quote
Old 08-10-2011, 01:10 AM   #9
AJ
AJ's Avatar
Pico Wheel Service in Van Nuys can do it... if you happen to live in the LA area.
AJ Elias
The Hot Rod Disorder
AJ is offline   Reply With Quote
Old 08-10-2011, 04:36 AM   #10
richard crow
buy a used front drum remove the bearings & use that. no maching needed
richard crow is offline   Reply With Quote
Old 08-10-2011, 05:45 AM   #11
BUBBAS IGNITION
Speedway motors for $49 Under wheel adapter stock car stuff
[email protected]
Old 08-10-2011, 07:15 AM   #12
TomT/Williamsburg
TomT/Williamsburg's Avatar
Go to www.innovativebalancing.com - works w/w-o tubes. I've used Dynabeads for over 10 years on my cars and they work like a charm.
TomT/Williamsburg is offline   Reply With Quote
Old 08-10-2011, 08:11 AM   #13
hbleadsled
Sturgis 39-I went to sacto.Ca. Areco arena swap meet Sun. HUGE and there was some w/w porta walls, have not seen those since the 50's Harold central coast Ca.
hbleadsled is offline   Reply With Quote
Old 08-10-2011, 08:27 AM   #14
jdl
jdl's Avatar
Send a message via ICQ to jdl
Thanks for the Dynabeads info, I never heard of them before . I think I will give it a try.
jdl is offline   Reply With Quote
Old 08-10-2011, 08:34 AM   #15
aerocolor
If you need a plate, Dick Sporado makes `em and they`re the nicest ones out there. All aluminum and about $75.
aerocolor is offline   Reply With Quote
Old 08-10-2011, 08:43 AM   #16
DICK SPADARO
Hey guys this is not a problem I have been making a wide 5 wheel balancer adapter for over 2 years, This will adapt any wide 5 to a conventional bubble or spin balancer and is made with the correct 1/2" lug studs not the stock car version 5/8" studs as posted. If you are interested call 518-861-5367 M-f 9-5 ET.
dickspadaro.com
DICK SPADARO is offline   Reply With Quote
Old 08-10-2011, 09:03 AM   #17
ken ct
Thanks for the info Dick. We have a place locally that has the old type balancer i mentioned above. Lucky i guess. ken ct.
Old 08-10-2011, 09:16 AM   #18
don's 37
don's 37's Avatar
Anyone have a wide five front drum they would sell for cheap just for the help of balancing? I'm on a strict budget here. Thanks for the options Guy's! Don
Old 08-10-2011, 11:16 AM   #19
DICK SPADARO
Don, this isn't a sales pitch but using a used hub to balance a tire might be the cheap way to do the job its not very accurate. The tire and wheel are balanced including the out of balance weight of the used drum. When you take the assembly off and install it on another drum the balance is now effected by the weight of that drum assembly, so unless you are one lucky guy the wheel and tire are now out of balance again.
dickspadaro.com
Old 08-10-2011, 11:23 AM   #20
don's 37
don's 37's Avatar
Dick: What do you need to get for your balance plate?
