09-02-2014, 10:21 PM | #41 |
Re: 6 volt relays
Pin 85 is Bat Positive ground.
Bruce
Works good Lasts long time |
09-02-2014, 10:35 PM | #42 |
Re: 6 volt relays
OK, no reason to connect it to the battery, but it is a ground and would work, sorry about that. I was seeing battery and thinking battery - power!. There would be no reason to connect a relay up this way as it defeats the purpose of using a relay in the first place, but I think it would work. Your basically replacing the dimmer switch with the relay. I think what you are saying matches the notes I attached above.
09-03-2014, 12:41 PM | #43 |
Re: 6 volt relays
Thank you
Bruce
