Old 04-15-2023, 06:18 PM   #1
oldspert
oldspert's Avatar
Default Canada Bought or Built
The block in my Model A is stamped with *CA 11XXX6*. Does mean My car was originally sold in Canada or just the engine was assembled there? Or maybe it is a replacement engine with the correct number on the title. One of the two previous owners were from Minnesota.
oldspert is offline   Reply With Quote
Old 04-15-2023, 07:18 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Canada Bought or Built
That Canadian engine number only means that the engine is Canadian, IMO.
By the time one of these cars reaches this age, there is a BIG chance that the engine has been changed at some time so the car may not be Canadian. Canadian cars had other differences not seen on American ones. My memory is a bit sketchy but I'm sure if I'm wrong, someone will correct me but the Canadian cars had holes in the chassis to take a RHD steering box and no number stamped on the chassis. Also, if there are any of the original screws still on the car, the Canadian ones used Robertson head screws whereas the American ones used slotted heads.
Hope that helps.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 04-26-2023, 10:01 AM   #3
Kinsley
I have a '31 T. S. with a CA preface engine number. Interior trim screws and some exterior screws are Robertson ( square hole ) head. I understand this car was built in Canada.
Kinsley is offline   Reply With Quote
Old 04-26-2023, 11:14 AM   #4
heneste
heneste's Avatar
Other differences between the American and Canadian cars were in the bumper clamps (at least for the 30-31s). The American cars had bumper clamps with recessed painted inserts and no appearance of bolt while the Canadian cars had solid clamps with a carriage style bolt running through the center.
heneste is offline   Reply With Quote
Old 04-26-2023, 01:29 PM   #5
Randy in ca
Randy in ca's Avatar
If it helps at all, the partial engine number you've given place it in the March/April 1929 period. What year/model is the vehicle?
Randy in ca is offline   Reply With Quote
Old 04-26-2023, 02:12 PM   #6
fundytides
fundytides's Avatar
If there is still a body number stamped on the left front door sill (subframe) that will tell you if it was built in a Canadian plant.
fundytides is offline   Reply With Quote
Old 04-26-2023, 02:21 PM   #7
fundytides
fundytides's Avatar
Here's info on body assembly plants and codes including Canadian built cars
https://model-a-ford.org/top-page-1/...-body-numbers/
Old 04-27-2023, 09:57 AM   #8
oldspert
oldspert's Avatar
year is 1929 coupe. It originally came from Michigan. First post was wrong for the location of original owner.
