Old 03-26-2020, 04:30 PM   #1
zoegrant
zoegrant's Avatar
Default Tach question
If a tach get its signal from the distributor, shouldn't the tach be hooked up "directly" to the distributor ?
The two wire tach I am using is hooked to the positive side of the coil where the wire from the back of the distributor is also attached.
Is their enough electrical signal from a setup like I have. ????
I still cannot get a correct tach reading, is it possible that the tach should be hooked directly to distributor ??
The other tack wire is hooked to ground.
This is a 272 Y Block....Thanks
zoegrant is offline   Reply With Quote
Old 03-26-2020, 05:39 PM   #2
dmsfrr
dmsfrr's Avatar
Default Re: Tach question
Previous thread...
https://www.fordbarn.com/forum/showt...7959&showall=1
This is on a Positive Ground car, right? With original style points? (not an electronic conversion kit)
There should be a usually black wire approx 1 foot long that connects the "+" terminal of the ignition coil to the points inside the distributor. There may or may not be a junction in this wire on the outside of the distributor. (photo)
Terminal #2 of the Tach should connect to either the Ignition Coil or Distributor end of that wire.
It's the same wire and shouldn't make any difference.
dmsfrr is offline   Reply With Quote
Old 03-26-2020, 08:03 PM   #3
zoegrant
zoegrant's Avatar
Thanks, that is all I needed to know...looks like I have it hooked up correctly.
Old 03-26-2020, 08:49 PM   #4
JimNNN
Thanks, dmsfrr. Per my PM, zoegrant, I'll try to get up to storage to check out how I wired mine, though I wired it per the instructions of the westech co. Also, I converted my wiring to negative ground, for what it's worth.
If you get it working before then, let us know. Thanks - Jim
JimNNN is offline   Reply With Quote
Old 03-26-2020, 09:14 PM   #5
zoegrant
zoegrant's Avatar
Jim … according to Westach a negative ground system is hooked differently but if it is not too much trouble I would like to see how it is hooked up..thanks
Old 03-26-2020, 10:02 PM   #6
dmsfrr
dmsfrr's Avatar
Looking at the instruction sheet for that Tach on the Westach website, there is a note near the top that says the two wires (for terminals # 2 & 5) can be reversed to 'steady' the needle if necessary.
This tells me the Tach isn't polarity sensitive, or you wouldn't have that option.
Unless their online instruction sheet is somehow out of date.
http://www.westach.com/instructions/2CT54-6V.jpg
Old 03-27-2020, 02:17 PM   #7
zoegrant
zoegrant's Avatar
I think my best bet is to send the tach in to Westach for examination, they have already authorized that...My contact there named Pete is really easy to work with. I believe he really wants to help. I will report back when the problem is straightened out.
Old 04-03-2020, 09:48 PM   #8
zoegrant
zoegrant's Avatar
PROBLEM SOLVED...It turns out that the tach was not for an 8 cylinder engine but for a 2 cylinder engine, probably a motor cycle. Some how the boxes at the company got mixed up. Even tho the box stated it was for an 8 cylinder turns out it was not.
So the company is converting it over to a 8 cylinder positive ground tach.
I have not received the tach back yet but I presume it will be good.
Thanks to all who gave good input...John in CT
Old 04-04-2020, 12:18 AM   #9
dmsfrr
dmsfrr's Avatar
Well.... that's good news and weird news at the same time.
Old 04-04-2020, 10:34 AM   #10
zoegrant
zoegrant's Avatar
Crazy stuff happens...someone who ordered a motorcycle tach might have gotten an 8 cyl positive ground tach. .The company said the tach`s are supposed to have a sticker on the back stating what application the tach is for. It might have been previously sold and the customer removed the sticker and then found he did not want the tach and made a return and who ever took the return in at the company got confused as to what application it was for and hence boxed it wrong and never put a sticker back on it and the next person who purchased it thought it was for a v8 and then resold it to me.
All speculation on my part but I trust the vendors completely. Like I said, stuff happens.
Old 04-04-2020, 11:30 PM   #11
JimNNN
Glad it's all fixed!! I agree that the folks who make this tach seem to be top notch.
In my review of the Westach 6 volt unit that I posted a while back, however, I cautioned that their website makes it easy to confuse the 8 cylinder model with the other models because they all look exactly alike. Apparently it isn't only customers who get confused by this but folks who work at the factory, too. No big deal. They'll make it right and zoegrant will be pleased with his tachometer.
