Old 06-28-2022, 02:06 PM   #1
Rand
Rand's Avatar
Default Vapor lock...😵www.jalopyjournal.net💫
Hi Ford Friends,
Drove my 50 Merc with a original Holly 885 carb to work today bc my truck is in the shop.. it's about 80° today in eastern Idaho and is vapor looking like crazy.. no flat out dying luckily. I know it's been discussed here a zillion times but im too lazy to search and I'm at work. Any tips or tricks for me? I have the wooden clothespins on the gas line going to the carb. really has never worked for me.
TIA, Randy
Rand is offline   Reply With Quote
Old 06-28-2022, 02:13 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Vapor lock...😵www.jalopyjournal.net💫
Install an electric fuel pump to 'boost" your stock pump.
Old 06-28-2022, 03:07 PM   #3
Rand
Rand's Avatar
49Fordy... Crazy you say that, I installed one 15 years ago back at the tank for cold starts. Just a few weeks ago it started leaking so I took it out so I could drive the car. I guess it's time for a new one with a on/off switch. Not a switch you have to hold on only while I'm cranking.. Where do you recommend getting a new 6volt one from and brand?
Old one was from Shoebox Central
Thank you!
Old 06-28-2022, 04:21 PM   #4
TJ
TJ's Avatar
Check with Napa Auto Parts. They may have one.
Old 06-28-2022, 04:42 PM   #5
feufeu
feufeu's Avatar
Hi guys,
i solved my vapor lock problems with installing little steel sheet to close the exhaust pipe going thru the intake manifold. did this last year, and i never had any more vapor lock!
feufeu is offline   Reply With Quote
Old 06-28-2022, 04:48 PM   #6
ford38v8
ford38v8's Avatar
Originally Posted by Rand View Post
Hi Ford Friends,
TIA, Randy
Randy, Before you buy a pump, climb under again and tighten the connections where you took off the old pump. You may very well be sucking air at that point, which would have the exact same symptoms as you described.
Alan
Old 06-28-2022, 04:59 PM   #7
Rand
Rand's Avatar
Randy
Old one was leaking
Old 06-28-2022, 05:00 PM   #8
Rand
Rand's Avatar
I solved my vapor lock problems with installing little steel sheet to close the exhaust pipe going thru the intake manifold. did this last year, and i never had any more vapor lock!
My Dad said he used to use year of manufacturer pennies in those holes
