Old 05-19-2010, 11:36 PM   #1
51PanelMan
51PanelMan's Avatar
Default 1951-1952 Ford truck cab and partial frame
City: San Jose
State: CA
Price: $150
Cab is stripped, but does come with the fuel tank, transmission cover and the two running board brackets that were removed from the missing rear half of the frame.
Cab needs work in all four corners. Someone along the years got too happy with the body filler and started to fill every hole in the firewall. Floor appears to be solid. Cab roof and back are straight.
I'll sell just the cab without the frame for $150. I'm just lazy to remove it from the frame. I'll also do whatever cuts you need for $150. If you need the roof section so you could finish your chop, $150. If you need the firewall, $150. If you need the back section, $150. You get the idea. I can ship the cut pieces via Greyhound.
Local pick up is preferred. However, local delivery is free, and semi-local delivery available at a reasonable cost.
Additional photos here: http://www.villagephotos.com/pubbrow...der_id=2124120
51PanelMan is offline   Reply With Quote
