Old 11-08-2020, 09:17 PM   #1
keyswitch1
Default Oil
What weight oil do you use ?? Thank you !!
keyswitch1 is offline   Reply With Quote
Old 11-08-2020, 09:20 PM   #2
McMimmcs
McMimmcs's Avatar
Default Re: Oil
You should do a search! There must be over 100 threads on this subject.
Old 11-08-2020, 09:55 PM   #3
shew01
shew01's Avatar
Default Re: Oil
I use Pennzoil 10W30 every 1000 miles. Some folks change oil every 500 miles.
Old 11-08-2020, 10:17 PM   #4
1crosscut
1crosscut's Avatar
Default Re: Oil
If you were to do a search you'd probably find that 10w 30w is most commonly used.
That is what I use.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 11-09-2020, 06:48 AM   #5
Benson
Benson's Avatar
Default Re: Oil
Search for the term "oil survey" (or similar) that several folks have done on FB.
These give many opinions in one posting.
Old 11-09-2020, 07:09 AM   #6
Gene F
Gene F's Avatar
Default Re: Oil
Anymore it's not so much the weight, as it is the chemistry.
Old 11-09-2020, 08:47 AM   #7
Mulletwagon
Mulletwagon's Avatar
Default Re: Oil
Shell 15W-40
Mulletwagon is offline   Reply With Quote
Old 11-09-2020, 09:12 AM   #8
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Oil
20 W-50 here for many years .
Old 11-09-2020, 09:25 AM   #9
Jack Shaft
Default Re: Oil
Diesel grade 15/40,rotella or delo.higher shear and load characteristics.
Old 11-09-2020, 09:33 AM   #10
Mister Moose
Mister Moose's Avatar
Default Re: Oil
Have you tried doing that?
Most forum search functions, including this one, won't search on 3 letter words. It must be a minimum of 4 letters. You can't search for only threads with oil.
You can add a second word to get past this, like "oil change", but then you are bombarded with useless threads on tire change, weather change, spare change, change in seasons, change your mind... you get the idea.
I also haven't seen the ability to require all words in a search on this forum, ie returned hits must include both oil and change. Some other BB software does allow this, and it's very helpful.
One thing you can do is search within topic titles only, that will help, but you will still have a lot of junk to sort through.
Mister Moose is offline   Reply With Quote
Old 11-09-2020, 10:18 AM   #11
Gary WA
Gary WA's Avatar
Default Re: Oil
Delo 400 15/40
www.whidbeymodelaclub.com
Old 11-09-2020, 10:19 AM   #12
Gary WA
Gary WA's Avatar
Default Re: Oil
Delo400 15/40
Old 11-09-2020, 10:40 AM   #13
Aretino
Aretino's Avatar
Default Re: Oil
Shell Rotella T1 SAE30
Aretino is offline   Reply With Quote
Old 11-09-2020, 11:30 AM   #14
Patrick L.
Patrick L.'s Avatar
Default Re: Oil
Rotella 15-40
Rotella T3 is CJ-4 and SW rated with 1200 ppm zinc
Old 11-09-2020, 12:05 PM   #15
WHN
Default Re: Oil
Have used 20w-50 HD oil for years. Walmart.
Also, I add one 16oz bottle of blue STP.
Change once a year or 500 miles. Very rarely make the 500 miles.
Engine rebuilt in the late 60’s, has about 10,000 miles on rebuild. Does not use any oil and compression is all in the mid 60’s. Good power and very quite. Marvel Mystery Oil in gas.
Old 11-09-2020, 07:35 PM   #16
California Travieso
Send a message via Yahoo to California Travieso
Default Re: Oil
I recently bought a case (2 five quart jugs) of Kirkland 5W-30 Fully synthetic oil from Costco for $30. It should be fine for winter since my car doesn’t leak or use oil.
I noticed Costco also has the 15w-40 diesel oil that a lot of Model A guys use. Their Kirkland brand comes in a three pack of 1 gallon jugs for $33. Might be good for summer here in So. Cal. when the temp hovers around 100 degrees.
Has anyone tried either of those?
David Serrano
California Travieso is offline   Reply With Quote
Old 11-09-2020, 08:26 PM   #17
marc hildebrant
marc hildebrant's Avatar
Default Re: Oil
Changed my oil today. Used 20-50W that I had.
When I first had the Model A I used the recommendation in the owners manual (20W Winter / 40W summer).
The 20-50W seems better.
Marc
Marc
marc hildebrant is offline   Reply With Quote
Old 11-11-2020, 12:21 PM   #18
Jim Brierley
Default Re: Oil
20-50, like others above. Diesel oils like 15-40 are not recommended by oil makers for gasoline engines.
Old 11-11-2020, 03:25 PM   #19
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Oil
I agree. I have been using Lucas Classic Car 20w-50 Motor Oil. at the recommendation of my engine builder.
Old 11-11-2020, 04:28 PM   #20
JKY
Default Re: Oil
David Serrano
We use it here in Utah. '28 pickup, 29 tudor, 29 fordor and a 30 tudor. All seem to like it.
JKY is offline   Reply With Quote
