Old 03-26-2024, 06:54 PM   #1
2speed
Default Timing gears
Snyders sells a macerated, a laminated, and a aluminum timing gear. The original is macerated and prone to disintegrating, laminated is better? Aluminum is bullet proof? Why sell a macerated gear?
2speed is offline   Reply With Quote
Old 03-26-2024, 07:34 PM   #2
gdmn852
gdmn852's Avatar
Default Re: Timing gears
Always a demand for a cheaper product.Was a post on here about non fitting repro parts and cost seem to come up quite often.
gdmn852 is offline   Reply With Quote
Old 03-26-2024, 07:40 PM   #3
Joe K
Joe K's Avatar
I'm not sure the original was macerated. More likely laminated. I would never go below this in a gear but there have been a lot of gears come and gone over the years and I expect macerated was an attempt at cutting costs.
Rick Freeman (Brazil Parts) comes to mind. Would they work? Yes. Would they work a long time? You're on your own on this.
Vince Falter has extensive discussion of aftermarket "high-end" metals gears, including one that was "timing adjustable." https://www.fordgarage.com/pages/camshaftgears.htm
Joe K
Shudda kept the horse.
Old 03-27-2024, 09:03 AM   #4
nkaminar
nkaminar's Avatar
Don't buy the cardboard ones.
Cardboard gear $1.69
Styrofoam gear $0.39
Cast concrete gear $4.99
3D printed gear, including labor $195
Old 03-27-2024, 09:30 AM   #5
2speed
I understand and read some of the price/quality issues, but the difference in the macerated vs laminated gear is $20. It's not exactly break the bank.
Better question, if you were replacing your gear laminated or aluminum?
Old 03-27-2024, 09:42 AM   #6
Flathead
Flathead's Avatar
Aluminum with a new or very good crank gear. My two cents.
Flathead is offline   Reply With Quote
Old 03-27-2024, 06:30 PM   #7
Synchro909
Synchro909's Avatar
That makes 4 cents between us!
Old 03-27-2024, 09:14 PM   #8
JayJay
Dan McEachern, who posts here, makes a great set of matched gears. Steel crank and either aluminum or bronze for the cam. I bought a set for my Burtz and they are works of art.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
Old 03-28-2024, 04:04 AM   #9
johnbuckley
johnbuckley's Avatar
[QUOTE=JayJay;2300732]Dan McEachern, who posts here, makes a great set of matched gears........[/QUOTE]
Did someone at Fords originally spend time matching gears or were they machined more accurately than nowadays ?
Old 03-28-2024, 10:19 AM   #10
Bob Bidonde
Bob Bidonde's Avatar
This slide shows the original timing gear and the modern reproduction. In my opinion, the aluminum timing gear has superior strength, but I am not to keen on having an aluminum gear being driven by a steel gear for a galvanic reason. Also, I suspect that the aluminum gear will have a higher wear rate than the laminated gear.
The slide shows an original gear where its aluminum hub has separated from the fiber which is a common failure mode of original gears. I replace all original gears I come across with modern reproductions.
From experience, I have thousands of trouble free miles on Bratton's 8750 Laminated Timing Gear, so it is a proven excellent choice. If I were to hop up the engine in my A's, then I would consider the aluminum gear.
Bratton's 356B Aluminum Alloy Gear #8760 is the lesser expensive option. 356B Aluminum is for casting. The primary alloy in 356B Aluminum is silicone with smaller amounts of copper or magnesium. The "B" designation is for the purity of the cast material with an "A" being the highest. I do not know what the heat treatment for hardness is of Bratton's aluminum gear.
File Type: jpg Timing Gear Original & Reproduction.jpg (58.4 KB, 85 views)
Bob Bidonde
Old 03-28-2024, 11:22 AM   #11
katy
katy's Avatar
Did Ford make their own gears? Or an outside supplier?
Old 03-28-2024, 12:37 PM   #12
Flathead
Flathead's Avatar
I would guess an outside supplier, they are often marked "Celoron"
Old 03-29-2024, 02:34 AM   #13
Dan McEachern
Celeron was a process/material developed by General Electric where canvas or linnen fabric was impregnated with phenolic resin. These 'prepegs" could be compression molded around a metal hub and then machined. Phenolic resin is a thermoset and once cured by heat and pressure does not soften with further application of heat. Westinghouse developed a similar product with the trade name Micarta.
No doubt these processes were licensed to Ford for timing gears or GE supplied parts to Ford.
Dan McEachern is offline   Reply With Quote
Old 03-29-2024, 07:26 AM   #14
Flathead
Flathead's Avatar
Thanks for the clarification on that.
Old 03-29-2024, 07:27 PM   #15
CarlG
CarlG's Avatar
I have Dan's bronze matched set in my Ron Kelley engine.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-30-2024, 11:17 AM   #16
Gene F
Gene F's Avatar
If ya get a motor rebuilt from a busy shop they always come home with an aluminum gear. Seems like them sitting is hard o the other gears. It's not always about miles.
Old 03-31-2024, 06:47 AM   #17
nkaminar
nkaminar's Avatar
If you have ever had to change the timing gear on the side of the road, you will use the aluminum gear.
Old 03-31-2024, 10:31 PM   #18
Herb Concord Ca
Times 2, I replaced mine in my garage.
Herb Concord Ca is offline   Reply With Quote
Old 04-01-2024, 02:07 PM   #19
Tom F OHIO
Tom F OHIO's Avatar
We replaced one in a farmers front yard years ago. Its not the easiest repair on the road.
Tom F OHIO is offline   Reply With Quote
Old 04-01-2024, 04:10 PM   #20
updraught
updraught's Avatar
What about the failure of the cast vs steel crank gear?
updraught is offline   Reply With Quote
