05-04-2018, 10:17 PM | #1 |
Ignition Condenser HELP!
Looking for some help with finding an ignition condenser that had a threaded stud or threaded hole where a wire lead can be attached to. Kind of like a model A condenser or a Lincoln v-12 type. Only exception is I do not want one with any brackets soldered on. Just want one that comes with a slip on type mounting bracket. Any help is appreciated!! Closest thing I could find was an Echlin IH200. Might have to see if that works! Hopefully someone has some good info! Thanks!
05-04-2018, 11:55 PM | #2 |
Re: Ignition Condenser HELP!
Old Harleys run that style. Try # 32726-30A condensor with screw stud , $8.95 from;
http://www.45restoration.com/ Edit; sorry, it has a bracket attached.
05-05-2018, 01:10 AM | #3 |
http://www.45restoration.com/Products/Condenser-wscrew-stud__32726-30A.aspx
Description: Condenser - screw stud w/nut SKU: 32726-30A HD Orig. Part #:1629-30 HD New Part #: Your Price $8.95
05-05-2018, 05:49 AM | #4 |
I've got a few , I think they were from a echlin combo GM set . It had the points and condenser as one . You simply unscrew the condenser , no brackets at all . I'll try to get a pic .
05-07-2018, 09:02 AM | #5 |
I found it and took pics . I only know how to email pics so if needed email me at [email protected]
Gary |
05-07-2018, 09:10 AM | #6 |
05-07-2018, 11:12 AM | #7 |
I'll just throw this out there. I am making reproduction brass "trash can" condensers using modern severe-duty film capacitors. These units are robust enough to withstand systems with generators and solid-core plug wire. They usually are sold to guys restoring high-end dual point/dual coil racing ignitions. I make a .22 micro-farad unit that is suitable for use with regular ignition system. They are a little expensive, but the supply of good originals seems to have completely dried up.
05-07-2018, 05:21 PM | #8 |
A standard motor products RC3 has a stud for a wire lead but not a threaded stud..
A Standard FD64 has a threaded hole, and while it does have a bracket it is poorly crimped on and is easily removed. |
