Old 12-12-2011, 01:39 PM   #1
BobM
Default Aluminum heads and electrolysis?
My first choice for a head gasket was the graphite type but piston to head clearance has caused me to use the thicker copper gasket. What can I do to minimize the effects of electrolysis associated with aluminum heads?
BobM is offline   Reply With Quote
Old 12-12-2011, 01:45 PM   #2
TRUCK_RAT
TRUCK_RAT's Avatar
Default Re: Aluminum heads and electrolysis?
I wonder if there's some sort of sacrificial anode like they use in boats that could be used.
TRUCK_RAT is offline   Reply With Quote
Old 12-12-2011, 01:53 PM   #3
36fordguy
Summit has them about $20. They go in the drain plug -36fordguy
36fordguy is offline   Reply With Quote
Old 12-12-2011, 02:17 PM   #4
Kahuna
Kahuna's Avatar
Go to Home Depot. Buy an anode for a water heater. Cut it in lengths of about 2". Drill a hole in one of the pieces. Attach via wire or small chain to the radiator cap. QED
Jim
Kahuna is offline   Reply With Quote
Old 12-12-2011, 02:24 PM   #5
jkeesey
jkeesey's Avatar
Snyders sells them for their model a's with aluminum heads
jkeesey is offline   Reply With Quote
Old 12-12-2011, 02:29 PM   #6
BobM
I knew you guys would have the answer, thanks.
Old 12-12-2011, 02:43 PM   #7
FlatheadTed
FlatheadTed's Avatar
I think you are in for sever corrosion Anode or not with copper , ,Use the composition if possible
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 12-12-2011, 04:11 PM   #8
keith oh
keith oh's Avatar
My experiance with aluminum head electrolysis is between the head and head bolts not the head and block causeing stuck heads. There is even a thin hole saw that is made to go over the bolts and release them from the head, the head then comes right off. I always put heady grease on all the bolts befor replaceing the heads and have never had a head stuck. I use standard Fel
keith oh is offline   Reply With Quote
Old 12-12-2011, 04:28 PM   #9
Fe26
Like keith oh says x2
Fe26 is offline   Reply With Quote
Old 12-12-2011, 06:18 PM   #10
cmbrucew
cmbrucew's Avatar
Keith oh
Where might one buy this thin hole saw you mentioned?
Thank you
Bruce
Works long time
Lasts long time
cmbrucew is offline   Reply With Quote
Old 12-12-2011, 06:28 PM   #11
4dFord/SC
4dFord/SC's Avatar
Lots of folks use this stuff as an alternative to the sacrificial anode: http://www.no-rosion.com/norosioncoolant.htm
4dFord/SC is offline   Reply With Quote
Old 12-13-2011, 05:04 AM   #12
FlatheadTed
Like I said plenty of corrosion with copper gaskets ,What do you do ,When you are a 100 miles from home, and your oil goes milky.Copper for cast iron ,Graphite/composition for Aluminum,Copper will set up a nice battery action against the aluminum. I could show you plenty of heads that have corroded right under the casket . If you have clearance issue then mill something .Also anti freeze left in to long after the use by date will do the same ,For removing heads you could also try and pour Coca cola/or vinegar down the studs and leave it.
Old 12-13-2011, 06:13 AM   #13
Ed Pitts
Ed Pitts's Avatar
If corrosion is a big problem with copper head gaskets, why does Edelbrock recommend copper head gaskets with their flathead aluminum heads? Ed
Ed Pitts is offline   Reply With Quote
Old 12-13-2011, 07:28 AM   #14
GOSFAST
GOSFAST's Avatar
We use "copper" head gaskets nowadays on just about all the Flatheads! Occasionally we'll use conventional pieces.
Make certain to maintain a 50/50 anti-freeze mix, preferably the "older" green color, not the "newer" red!!
Not sure how many here recall all the issues with the "Vega" aluminum blocks, but they would begin "disintegrating" at the cylinder walls (there were no liners in the bores, the "tin-plated" pistons ran on the aluminum walls) when the anti-freeze started to become "diluted". Eventually they smoked bad enough to be rebuilt. Upon rebuilding them all 4 cyl's got sleeves! We learned much from this condition.
Thanks, Gary in N.Y.
P.S. Just an add'l word of caution, make certain also that ALL "ground" connections are kept "clean", this is important!
GOSFAST is offline   Reply With Quote
Old 12-13-2011, 11:46 AM   #15
FlatheadTed
These days you may get away with it because of the better quality Aluminum ,I would not recommend it on any old stock Cylinder head .Ford sold and recommended composition gasket for Aluminum heads. All modern cars use the composition Gaskets , .
Old 12-13-2011, 01:41 PM   #16
super flat
super flat's Avatar
I think I might have a clearance issue with my alum heads and if so I thought about running a copper gskt by the block and graphite by the head stacked. Would this still cause corrosion? Thanks Gary
super flat is offline   Reply With Quote
Old 12-13-2011, 02:22 PM   #17
Jack E/NJ
Jack E/NJ's Avatar
Non-conductive composition gaskets are probably safest in contact with aluminum.
Jack E/NJ
Old 12-13-2011, 03:43 PM   #18
FlatheadTed
I wouldn't run 2 Gaskets if you can help it ,because of sealing issues ,Plasty gouge the head to piston clearance ,Then decide were to take the material of ,You could do a search of the subject , Or someone like old Ron could Chime in
Old 12-14-2011, 01:54 AM   #19
earlyride
earlyride's Avatar
I'm using a product called Water Wetter. Added to your coolant it's suppose to help cooling, and prevent corrosion, so I've been told.
earlyride is offline   Reply With Quote
Old 12-15-2011, 05:50 PM   #20
BobM
How do you recognize an electrolysis condition? I have a '36 with aluminum heads & copper head gaskets and I would like to be able to tell if electrolysis is present.
