04-04-2012, 05:41 PM | #1 |
Alignment Camber Problem
Newbe here. Recently purchased a 29 Pick-up and the RF wheel is clearly miss-aligned. Looking from the front, the top of the wheel is leaning to the outside of the vehicle and tire wear is much more prominent on the outside edge of the tire. The left front wheel looks normal and tire wear is even.
The vehicle handles and drives fine, but obviously I have a problem. The books I have tell me how to adjust toe-in and caster, but camber seems to be fixed (?). Any suggestions as to what I should look for to correct this problem. Bearings seem OK. Thanks in advance Last edited by Contenderizer; 04-04-2012 at 05:43 PM. Reason: spelling |
04-04-2012, 05:50 PM | #2 |
Re: Alignment Camber Problem
My first thought is a bent axle.
Rich
E30 68-B Cabriolet
04-04-2012, 06:22 PM | #3 |
I agree with Rich, you probable have an axel that is bent at the problem end. This is not uncommon problem as hitting chuck holes and curbs over the years often effects the axel.
Ron |
04-04-2012, 06:23 PM | #4 |
The axle can be straightened, make sure you give the shop the proper data from new.
04-04-2012, 06:41 PM | #5 |
Kevin in NJ has a nice website. There he has many tech articles, here is one of his just on that subject, if your a doit yourselfer.....
http://home.comcast.net/~68c/Front_a...aightening.htm
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
04-04-2012, 08:07 PM | #6 |
Rich
E30 68-B Cabriolet
04-04-2012, 10:07 PM | #7 |
A large truck or spring facility, or front end shop can probably 'form" it on the car w/out dis-assembly.
Paul in CT |
04-05-2012, 12:42 PM | #8 |
I had one once like that and it was a bent spindle probably from slamming a curb sideways at some time. I would say to check the spindle first, if ok then I would look for a good axle. I bought a nice axle awhile ago for $30.
04-06-2012, 09:21 AM | #9 |
Thank you all.
If I am looking for a replacement axle, what shall I look for? Are all axles (except AA) the same? Are they stamped for identification? |
04-06-2012, 09:48 AM | #10 |
I had the same problem on a early 28 roadster pick up, and it was a bent spindle.
mike |
04-06-2012, 06:43 PM | #11 |
AA's are a much heavier axle. Good A axles are plentiful, sight down the length for straigtness and check the bores for a good snug fit on the kingpins. I brought a good kingpin with me to check fit when I bought mine.
