08-19-2013, 03:56 PM | #1 |
Earlier Post...
Earlier I had posted that my car started dying after driving a mile and barely make it home, spitting and sputtering and backfiring. Well it turns out the battery went bad and I'm guessing that the cutout switch was causing the backfiring like if I was turning the key off and on. In the meantime I took the distributer apart and the carb only to not find anything there to cause the problems.
My questing here now is; should I use permatex on the gaskets on the carb to make sure no air leaks occur.
I work very hard to avoid all and any mistakes. I thought I made a mistake once, but I was wrong. |
08-19-2013, 04:26 PM | #2 |
Re: Earlier Post...
Hi Tom,
A. Usually if it starts OK; then runs OK for up to one (1) mile; then begins sputtering & backfiring, many times the cause is: 1. Poor fuel flow; and/or, 2. Condenser and/or coil are getting hot & are failing. B. Next, Permatex cannot harm gaskets;; however, if gaskets are severely mashed, or torn, best to get new gaskets which are not expensive. C. If cutout is bad, get a new one. More specific details cannot hurt to try to fid out what is going on. |
08-19-2013, 06:34 PM | #3 |
Re: Earlier Post...
vent on the gas cap may be plugged
08-19-2013, 07:43 PM | #4 |
Re: Earlier Post...
Gentlemen thanks for getting back to me. I found nothing wrong with the carb. I do have new gaskets. The battery is dead. Won't take a charge..load test confirms. Not sure about the burnout proof condenser yet. Gas cap is loose..shouldn't have been a factor...cutout is the diode type. The most obvious thing at this time is the battery.
08-19-2013, 10:02 PM | #5 | |
Re: Earlier Post...
08-19-2013, 07:50 PM | #6 |
Re: Earlier Post...
08-20-2013, 01:03 AM | #7 |
Re: Earlier Post...
08-19-2013, 10:19 PM | #8 |
Re: Earlier Post...
No sealer needed.
08-20-2013, 01:29 PM | #9 |
Re: Earlier Post...
Diode seems to be working well. Heard the horror stories on the cutouts, so went with the diode type. Thanks for the imput on the permatex...I won't use it. Is there soposed to be lock washers on the carb to manifold bolts?
08-20-2013, 02:04 PM | #10 |
Re: Earlier Post...
Yes I believe there should be lock washers on the carb bolts.
08-20-2013, 03:17 PM | #11 |
Re: Earlier Post...
cool good to know and i also believe theres supposed to lockwashers...
