Old 05-26-2014, 07:36 PM   #1
Ol' Ron
Ol' Ron's Avatar
Default Yransmission help
Hi Guys, Have this RTS 3 sp w/OD and can't get the shift cover off the trans to install it into the truck. Have it bolted on the engine and would like to put it in but the stick is in the way. Is there a way to rempve just the stick? I have all the bolts off the cover nad tried to pry it of like an old ford box bit I'm afraid to brake it. Thanks
Old 05-26-2014, 09:02 PM   #2
Bob C
Default Re: Yransmission help
I had to put mine in 2nd gear to get the cover off the trans.
Bob
Old 05-26-2014, 09:05 PM   #3
Ol' Ron
Ol' Ron's Avatar
Very interesting, thankyou. Have to go to the VA tomorrow and will try that when I get back.
Old 05-26-2014, 10:23 PM   #4
Teich
If you just need the lever off ,un screw the retaining cap and it pulls out, as does mine. Laurie
Teich is offline   Reply With Quote
Old 05-26-2014, 10:25 PM   #5
Bassman/NZ
Bassman/NZ's Avatar
Mine too. I put mine in neutral, then unscrew the lever. It's hard to get back in if not in neutral. If you take the whole top off it's best in 2nd as someone else said.
Bassman/NZ is offline   Reply With Quote
Old 05-27-2014, 05:55 AM   #6
Ol' Ron
Ol' Ron's Avatar
Did't think there were that many of these trans out there. thanks.
