11-14-2017, 02:17 PM | #1 |
Ford script on generator
I picked up a generator and after cleaning it I found a Ford script.
Is it rare to have a ford script on a generator? And what do the numbers mean? |
11-14-2017, 02:54 PM | #2 |
Re: Ford script on generator
do you have a pic of the entire generator?
1929 Model AA - Need long splash aprons! |
11-15-2017, 05:19 AM | #3 |
I'm wondering if it's a N tractor generator? My 1950 8N has Ford script on the barrel.
I'm with SS, a full view photo will help answer you question.
I Love Anything That Turns Money Into Noise |
11-19-2017, 11:34 AM | #4 |
Do these photos help?
11-19-2017, 01:22 PM | #5 |
Yep, it's post Model A production.
11-19-2017, 01:36 PM | #6 |
11-19-2017, 04:13 PM | #7 |
Am i correct in saying a model A generator never had wires coming out of the case? They always had a stud?
11-19-2017, 11:25 PM | #8 |
11-19-2017, 11:33 PM | #9 |
The chamfered aluminum front and back plates were 1933-34 or newer (where they were supplied as a service part).
Charlie Stephens |
11-20-2017, 09:17 AM | #10 |
Thanks guys, I learned something new. Yep, at my age.
04-07-2018, 09:21 AM | #11 |
On this generator where would the 2 wires coming from the back of the gen be attached to?
This is the same gen as noted above. |
04-07-2018, 09:50 AM | #12 |
04-07-2018, 11:15 AM | #13 |
The Dog "sed" I should have a STAMP made & we could make $$$$$s, stamping parts!
Bill Broke
04-07-2018, 01:54 PM | #14 |
One to ground and one to the cutout.
04-07-2018, 07:50 PM | #15 |
Someone used a starter band on your generator. Generator bands don't have the notch cut in the edge. From the looks of the missing insulation, you better check the wires inside the generator also. The wire that leads to the field winding is the one that gets mounted under the cutout mounting screw. The other wire goes to the cutout input terminal.
Liquid Tape makes for good repairs for missing insulation, if too much isn't missing. |
