Old 05-19-2010, 11:36 PM   #1
51PanelMan
51PanelMan's Avatar
Default 1951-1952 Ford truck cab and partial frame
City: San Jose
State: CA
Price: $150
Cab is stripped, but does come with the fuel tank, transmission cover and the two running board brackets that were removed from the missing rear half of the frame.
Cab needs work in all four corners. Someone along the years got too happy with the body filler and started to fill every hole in the firewall. Floor appears to be solid. Cab roof and back are straight.
I'll sell just the cab without the frame for $150. I'm just lazy to remove it from the frame. I'll also do whatever cuts you need for $150. If you need the roof section so you could finish your chop, $150. If you need the firewall, $150. If you need the back section, $150. You get the idea. I can ship the cut pieces via Greyhound.
Local pick up is preferred. However, local delivery is free, and semi-local delivery available at a reasonable cost.
Additional photos here: http://www.villagephotos.com/pubbrow...der_id=2124120
51PanelMan is offline   Reply With Quote
Old 07-30-2010, 12:20 AM   #2
51PanelMan
51PanelMan's Avatar
Default Re: 1951-1952 Ford truck cab and partial frame
Anyone at $150??
Old 08-27-2010, 01:22 AM   #3
51PanelMan
51PanelMan's Avatar
$125 now.
Old 12-31-2010, 01:14 AM   #4
51PanelMan
51PanelMan's Avatar
Ok, last call at $100. The front leaf springs are worth that price alone.
Old 03-02-2011, 12:27 AM   #5
51PanelMan
51PanelMan's Avatar
Still available and would like to see it leave.
Old 06-02-2011, 12:47 AM   #6
51PanelMan
51PanelMan's Avatar
Just added front clip, hood and stripped out doors. Everything now for $175 or best offer. Great start for a custom rod or use for parts. Needs to be gone by end of June or will be scrapped. I lost the storage space and no room for it at my house.
