Old 01-03-2012, 01:50 PM   #1
jea777
Default Model B Distributor w/ Modern points, Cond. & Cap. Coil & Resistor.
City: Siler City
State: NC
Distributor was bead blasted & painted black, then rebuilt with new upper & lower shafts, weight springs, bushings, best B-style cam, modern Motorcraft points & condenser and special concave spring unique to the B distributor. Also, new dowel pin which engages the head. Assembly was checked & tuned on a Sun distributor machine and test-run on my Model A.
Can be used on 1928-1931 Model A without Pop-out style switch, plus 1932-1934 B-style engines.
The 6-volt Ford reproduction script coil has only been used during the engine testing.
The ballast resistor allows use of the coil with a 12-volt system.
$170. Shipping: $15 for all; includes delivery receipt.
Pictures would not load. Available by email.
jea777 is offline   Reply With Quote
