02-28-2015, 12:08 AM | #1 |
47 Tranny won't go into 3rd gear
I had this problem a while back but it was just the linkage from the steering column catching on the brake pedal return spring. Easy fix. Now it's not that nor anything external but something inside the transmission. I'm wondering what the chance is of removing the side panel with the shifting levers in it and finding something that can be fixed without removing the tranny from the car. Any ideas?
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
02-28-2015, 12:59 AM | #2 |
Re: 47 Tranny won't go into 3rd gear
I'd say slim to none
02-28-2015, 09:37 AM | #3 |
does it feel ike it goes into 3rd, --the shift lever move as far as before problem
Have you tried to shift it at the trans with the linkage disconnected |
02-28-2015, 09:41 AM | #4 |
OH,
I'm with Kurt, if you can get 2nd gear with no sweat hopefully you'll find an external problem. Charlie ny Pepe wants to GO !! |
02-28-2015, 10:16 AM | #5 |
High gear is a direct coupling of the input to the mainshaft output through the synchroniser. It could still be something with the shift mechanism so Kurt in NJ has a good check for that. If that doesn't work and there is a failure of a blocker ring or the synchro teeth, the transmission will have to come out.
02-28-2015, 10:58 AM | #6 |
A little wear "here", a little wear "there" and you end up with shifting issues. With all due respect, you are not known for maintaining quality components on your sedan. Once you KNOW the linkage is in "as new" condition AND the rods are adjusted CORRECTLY, only then would I think to open the transmission. "First things first" as is often said. If the above does not solve your problem, all repairs within a transmission dictate the transmission must be removed.
02-28-2015, 12:39 PM | #7 |
Repeating my answer to your question originally asked, no way, but heed Kubes advice to eliminate the linkage issues. He's right on.
02-28-2015, 01:23 PM | #8 |
I agree with you Russ in that it is probably the transmsission as the root cause of the issues mentioned. However, like you, I figured it best to eliminate the "easy fix" stuff before tearing out that transmission.
02-28-2015, 01:46 PM | #9 |
As generally mentioned above, I would investigate.
I would set the car up on stands so I can get underneath safely. I would then observe underneath while an assistant moves the shifter into top. I would then see if the trans would then go fully into top with a bit of manual assistance from below. The course of action would be dictated by the findings. Scenario 1: if the trans goes half way in with the linkage and then fully in with manual help then the linkage needs reworking or if in good shape, adjusting. Scenario 2: If it doesn't want to go into top even with help from underneath, I would remove the linkage and try and engage all gears by hand from underneath. I'd need the results from the tests so far to be able to suggest any further steps. Mart. |
02-28-2015, 01:54 PM | #10 |
That's about as straight-forward as it gets, Mart. Only reasonable plan of action......not hard to figure out. No "secret" mystery-fixes. DD
02-28-2015, 02:06 PM | #11 |
Funny. I just finished my 6 day 2,379 mile road trip to Mexico with no mechanical problems other than flat tires and the next day this happens. Weird. Just weird. My guardian angel must have been working overtime on the trip.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 02-28-2015 at 02:42 PM. |
02-28-2015, 02:39 PM | #12 |
Are you able to put in neutral, could be you are locked in two gears.
Column linkage should be about even in neutral. |
02-28-2015, 02:44 PM | #13 |
Not locked in two gears. Will go in all gears and neutral except 3rd. Linkage is OK. It's inside. Just wonder what it might be and if it might be just the forks and that mechanism that I might fix by removing just that without removing the whole transmission. That's all.
02-28-2015, 02:50 PM | #14 |
You can remove the side cover, if it no good you have nothing to lose.
02-28-2015, 03:55 PM | #15 |
Be sure first that the shift lever on the trans is definitely capable of putting it into third gear. I would get the rear wheels up and free off the floor. Prop the clutch pedal down to the floor. Remove the shift link rod from the front lever. Try to shift the lever into high gear by pushing the lever toward the rear of the car. If it doesn't go all the way in, have someone rotate the rear wheel slightly. If it still won't go all the way into third, something internal is preventing it.
Generally the problem would be one or two of the synchro inserts hung up or a piece broken off, preventing the full travel of the shift. This will require getting the trans out and apart.
02-28-2015, 04:15 PM | #16 |
Professor,
I hope your transmission problem turns out to be a simple linkage problem. When you get a chance, tell us about your trip. John |
02-28-2015, 04:20 PM | #17 | |
Thanks, Mac. That's just what I wanted to know.
02-28-2015, 04:21 PM | #18 | |
Stay tuned.
03-04-2015, 09:49 PM | #19 |
And the winner is . . . Mac VP.
Took the gearshift housing off, hoping it would be a problem with that. It wasn't. It was as Mac said, the syncro sleeve slides fine into 2nd than back to the neutral position but will not slide into 3rd position no way. It doesn't even get close to the syncro ring. So, it's gotta be one of those stupid little inserts or balls that are messed up keeping it from sliding. Easy fix once I get the thing out of the car. But, as Mac said, the whole shebang's gotta come out. That'll be another day. At least I know now.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 03-04-2015 at 09:58 PM. |
03-06-2015, 12:14 AM | #20 |
Here's the culprit:
That's the 1" long insert in the syncro hub. That itsy bitsy broken off piece jammed the synchronizer ring so that it wouldn't shift the little bit that it need to to allow the sleeve to slide onto 3rd gear. That was it. Whoda thunk? Price to replace broken part? One dolla bill.
03-06-2015, 02:37 AM | #21 |
Wow. good find.
Hopefully it should be a straightforward fix. Mart. |
03-06-2015, 08:07 AM | #22 |
My first question would be why did it break?
03-06-2015, 08:18 AM | #23 |
Henry i would replace the synchronizer hub with a newer version without the balls. They work better.
03-06-2015, 08:53 AM | #24 |
Talk to Mac VanPelt to get his experience. IMO the 81A syncro hub, you have, is strong, but I use the 3 thick, wide, solid metal inserts for the 3 steel balls instead of the stamped steel insert, that has broken for you. The thick metal inserts are a direct replacement to your broken insert. I would not use the style hub for the 3 thin cast metal inserts. These seem to crack and brake. I stay away from the hub and inserts that use the two large diameter spring rings on each end. The inserts are again stamped steel and the spring rings can loose some of their ability to spring back. Since you have it apart check ALL the end plays and replace both of the blocker rings, bearings, thrush washers. Have some fun doing the job.
03-06-2015, 09:51 AM | #25 |
I've had good luck with the spring ring set up in my Mercury overdrive transmissions. On last overhaul, one of the transmissions had 140K miles and the synchro assembly was still in very good condition. The old ball bearing types used to break the little springs under the balls so they had their ups & downs too. Everything wears out eventually. Old Henry is still in every day service so things will wear out.
03-06-2015, 09:52 AM | #26 |
Here's the ring showing where the little piece jammed it.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 03-06-2015 at 09:59 AM. |
03-06-2015, 02:18 PM | #27 |
Henry,
Ask Mac for the solid keys not the die stamped variety. Charlie ny |
Thread Tools | |
Display Modes | |
