Old 12-22-2013, 11:52 AM   #1
stallerl
stallerl's Avatar
Default Removing Built Up Wax From Body Seams?
My '29 Tudor has an older black paint job that has lots of dried white wax built up in the body seams. I want to remove it without using a wheel, preferring to do it by hand. I searched here, you tube and other car sites without success as to what to use to remove the dried wax. Could something as simple as warm water and a soft toothbrush work? Or do I have to clay bar the area? I read that Dawn dish soap works well. (Does it have to be only Dawn?)
Any suggestions on what would be best to get rid of the old wax crud?
Thanks.
stallerl is offline   Reply With Quote
Old 12-22-2013, 11:59 AM   #2
28ACoupe
28ACoupe's Avatar
Default Re: Removing Built Up Wax From Body Seams?
Tooth brush.
1928 Model A Business Coupe
Rebuild picture gallery here
The light at the end of the tunnel has been turned off due to budget cuts.
28ACoupe is offline   Reply With Quote
Old 12-22-2013, 12:51 PM   #3
Tiny
Tiny's Avatar
Toothpicks can also be a usefull tool for those hard to get at spot, but a toothbrush will get most.
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 12-22-2013, 01:02 PM   #4
green30coupe
green30coupe's Avatar
Detailers use what they call a cut-off paint brush. Detail suppliers sell them and I suppose you could carefully cut a soft bristled paint brush flush and about ¾" from the metal band to make one yourself.
Ed
LAW OF MECHANICAL REPAIR
ONCE YOUR HANDS BECOME COVERED WITH GREASE,
YOUR NOSE WILL ITCH AND YOU'LL HAVE TO PEE
green30coupe is offline   Reply With Quote
Old 12-22-2013, 01:09 PM   #5
glenn in camino
glenn in camino's Avatar
I'd use a tooth brush dipped in grease and wax remover. Then use some of that black wax made for black and dark colored cars.
Old 12-22-2013, 02:35 PM   #6
stallerl
stallerl's Avatar
After trying a toothbrush I landed up getting the best results with a q-tip and Ivory Liquid dish soap. I found that the toothbrush was lightly scratching the surrounding area even though the brush was a super soft sensitive type. What didn't come off with the q-tip I carefully used the point of a toothpick. I then followed up with Mequires black wax. While it's not perfect it's a lot better. Thanks for all the tips!
Old 12-22-2013, 02:41 PM   #7
V4F
V4F's Avatar
when done , use a wax that does not leave the white ........
V4f
V4F is offline   Reply With Quote
Old 12-22-2013, 02:51 PM   #8
stallerl
stallerl's Avatar
I did. I used Meguiar's Black Paste Wax. Although it's not really black in color, more like a gray it sure does look better then the old dry white wax that was it here. Thanks!
