11-07-2014, 08:09 AM | #21 |
Re: What is reasonable charge for engine work? 59A
It won't be cheap. It will likely. Be at least $2500 and likely more. Please let us know.
Wayne |
11-07-2014, 09:37 AM | #22 | |
Old Henry, you have indicated
Nomad |
11-07-2014, 09:48 AM | #23 |
Building Flatheads sounds cheaper than doing a Model A Ford 4 banger. They run four grand right off the top and hopefully you can find someone who knows the RIGHT way to pour babbitt or else you are looking at another rebuild in a thousand miles or less. Happens all the time read the Model A side
11-07-2014, 10:17 AM | #24 | |
The threads are rolled threads...not cut. So if you run a standard tap or die over the threads or in the block your really gonna have a leaker
Thee Inland Emperors |
11-07-2014, 11:16 AM | #25 |
There is some good info here for the home shop. Rolled threads aren't used in holes only studs bolts and screws.
http://www.kmstools.com/blog/hand-ta...ng-techniques/ R |
11-07-2014, 11:24 AM | #26 |
11-07-2014, 11:46 AM | #27 |
Almost all of these numbers seem low to me, you guys must have some really great deals going with the mechanics. One issue I see is we are mixing apples and oranges here. Most of the price quotes were for machine work only on a carry-in carry-out engine or for machine work and assembly on a complete rebuild. This was driving a car in and having it fixed. The shop had to pull the engine, disassemble it, determine the problems and research how to fix it, get the parts, reassemble it and reinstall it. I'm sure a shop familiar with working on flatheads would be much quicker at it, but that was not the case. So, I think comparing basic machine work or the price of a rebuilt engine is not going to compare very well.
11-07-2014, 11:59 AM | #28 | |
In fact, in this area to get the job done correctly, it's in the $4000+ range.
11-07-2014, 12:32 PM | #29 |
Gosh, I recall that in 1963 I paid $5 a hole to have my flatty bored to 3 3/8"
But, I was making $1.15 an hour stocking shelves at a Grand Union super market. |
11-07-2014, 12:43 PM | #30 |
I totally agree with JSeery here, regarding the mixing of apples and oranges. A price point of +/- $6k is not unreasonable at all considering the removal, repair (rebuild), and re-installation.
Here I think it would be closer to $10k |
11-07-2014, 02:08 PM | #31 |
Seems like around here it runs, neighborhood, $2,500- $3,000 for a complete job, turning down crank, everything. That's what friends have told me.....
11-07-2014, 03:21 PM | #32 |
For labor only (I supplied all the parts) I had 8 holes bored 0.030, crank turned 0.010, rods reconditioned, two cracks pinned (and two valve seats bored and installed), cam bearings installed, 16 valve seats cut and entire short block reassembled for about $1500. The parts cost me about $1200 from different sources.
I dropped off and picked up the short block from the shop. If I had just dropped off the car and picked it up the same job could easily have been $6000. |
11-07-2014, 04:46 PM | #33 | |
R |
11-07-2014, 05:50 PM | #34 |
Most folks in the hobby probably do most of the work themselves like I do. I have all the labor saving devices to do everything by myself. I farm out the machine work since I don't have the required equipment for that. I take extra time to clean & restore finishes and the like that most shops don't do because I like a tidy job on my own stuff. I would have to charge a mint to do someone elses job if I did it like my own.
If you asked the average auto shop what they would charge for a flat rate on an old flathead vehicle, they wouldn't have any idea since most have never come close to one. It's fewer and farther between the shops that actually have done it enough to be able to flat rate any of the work. Shop rates down here seem to be between $75 & $85 per hour these days but some figure the parts bill up then multiply that by 2 for the labor if you can believe that. I've seen it before and that's another reason I do it all myself. |
11-07-2014, 06:05 PM | #35 | |
You will probably split a few knuckles and lean some new swear words. I have in the past cleaned the top threads of the studs with a die. Didn't cause a problem, I know it's not the best thing to do. Not the course bottom threads, just wire wheel on a bench grinder, or small wheel in a drill press running fast. Studs out, just wire wheel in a drill motor over the deck. Martin. |
11-07-2014, 06:31 PM | #36 | |
11-07-2014, 08:09 PM | #37 | ||
I'm talking about the threads that the nut goes on to hold the head down, i'm aware of the threads in the block being different and that you definitely shouldn't use a tap in them, rather a thread chaser. Quote:
11-07-2014, 08:34 PM | #38 |
As I explained previously, I didn't ask my question to judge the reasonableness of what I'd already paid. If I cared about that I would have asked before I took it in. I was just glad to find someone willing to work on it who was recommended by a local member of the EFV8 club. The amount I paid was within the range of what I expected to pay and I was not and am not dissatisfied with it. I was just asking in case they wanted more money for redoing everything. They didn't. So, I'm good.
I drove 300 miles last night and today on a quick overnight road trip with Pepe and the engine ran smoother than it ever has. I was accidentally creeping up to 75-80 mph without even realizing it, and could still see through my mirrors (previously at those speeds I'd have just enough vibration to shake the mirrors so I couldn't see clearly through them.) I didn't ask the garage for an estimate when I took the car in because I wasn't even sure what was wrong with the engine nor what would have to be done and knew they could not estimate without knowing. They just gave me their hourly shop rate of $85 and dug into it. The mechanic was very meticulous and maybe slower than one that had worked on flatheads all of his life but I didn't have any of those around any more. When I picked up the car and they gave me the bill I just wrote them the check, grateful to have the car on the road again.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
11-07-2014, 08:45 PM | #39 |
Good news on your test drive. Now enjoy & drive the crap out it. You can't put a price on happiness or can you? Maybe some do but I don't.
11-07-2014, 08:52 PM | #40 |
Since it is fairly certain that we can't take our money with us to the other side, I'm spending mine on memories of this life that I'm pretty sure will go with me.
Likewise, having a garage full of "trailer queens" when I'm 90 wouldn't bring near the peace and happy memories as driving my one old flathead to death over and over and over again as long as I can.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 11-08-2014 at 12:55 AM. |
