10-18-2014, 06:07 AM | #41 |
Re: Ideas for vibration problem in 59A
Bobh, if the engine is a real bear to get in or out, I sometimes make fire and smoke on the floor with them. Oil pressure, check, no leaks, check. Flick it in the car, connect it up, make necessary adjustments, and drive it hard.
As has been posted many, many times, you can easily undo The bore hone and ring seal by running a new engine on a stand with no load. Martin. |
10-18-2014, 06:12 AM | #42 |
I may have it wrong, but the flywheel has been in bad shape for a while. If it has been skimmed, it may not have been for the first time. The factory balance may have been lost. I would be looking for a non skimmed but serviceable 59A flywheel that still has it's factory balance. If not have the flywheel and clutch balanced as a unit.
As Colin says, if they are checked and are within balance specs, the imbalance must be deeper within the motor. Sorry to always seeming to be the bearer of bad news. Mart. |
10-18-2014, 07:35 AM | #43 | |
Lonnie |
10-18-2014, 07:46 AM | #44 | |
They have already proven to be well, less than proper mechanics / machinists. Best of luck...
10-18-2014, 08:55 AM | #45 |
You should have the shop stop and check the balance of the current assembly before they go to all the trouble of purchasing a new assembly and installing the engine and only to find out the vibration isn't the clutch flywheel assembly.That is a simple trouble shoot as to where the balance problem occurs.If they don't confirm the trouble from the get go they won't enjoy removing everything for the third time fixing it and being the proud owner of two clutch assemblies.If I were you all would halt until the suspect clutch has passed or failed the balance check.This is not rocket science just common sense.The problem isn't flathead related at all only someone shooting in the dark hoping for a successful outcome.
R |
10-18-2014, 10:01 AM | #46 |
When a flywheel is balanced off the crankshaft it is centered on the mandrel at the pilot bearing hole ----if tghe crankshaft wasn't properly centered in the crankshaft grinding machine there will be runout at the flywheel mounting I had this problem with model A crankshafts ---3 different shops, .004 to .008 off center, was told by shops "it's just an old car, it won't matter" I have bought several sets of Ford boxed rods,and pistons, all were balanced to +- 1 gram ,so Ford worried about balance on the production line and had tighter specs than most companys do |
10-18-2014, 10:30 AM | #47 | |
It is my feeling that Olhenry chose yet another "chop shop" to do the so called 'rebuilding" of his engine and is once again suffering the consequence of that choice. With the very apparent damage that was done on that engine prior to this "rebuild" ANY decent mechanic / machinist would have INSISTED on being extremely thorough this time around. The way that engine was (described to be) knocking in a previous thread, it is within a fair certainty that the rods were hammered out of true and most likely out of round. Yet no mention was made of the rods being reconditioned and subsequently balanced. Also, no mention that the engine was COMPLETELY dissembled and properly cleaned. Another thing ANY half way decent mechanic / machinist would insist upon. I truly hope this works out eventually in a good way but all the signs are pointing away from that outcome.
10-18-2014, 10:41 AM | #48 |
X2 on the factory balance.
I would be worried about trash in the oil passages and the condition of the rods on the bad throw. I think the engine should be pulled completly down and the main oil galley cleaned. The oil pump, cam bearings and even the cam in suspect due to the trash. The cam has to come out to remove the fuel pump bushing. I would send you my driver. I don't thing you should continue with the floating bearings and crank. Nobody in a shop would know how to check and fit them. The 8BA stuff is easy to check. You could run the engine on the floor without the clutch as a check. Pull the pan and the clutch and reinstall the pan. It would be nice if that fixes it. I would still pull it down and check the rods for dammage and the oil passages. |
10-18-2014, 11:02 AM | #49 |
[QUOTE=Andy;964509]X2 on the factory balance.
I don't thing you should continue with the floating bearings and crank. Nobody in a shop would know how to check and fit them. The 8BA stuff is easy to check. Really? No one? Um, there are a LOT of guys that do in fact have the skills required to check them properly. In fact, any decent machinist that did not have the experience should be smart enough to figure it out. These engines are fairly simple...
10-18-2014, 11:25 AM | #50 |
Being a very simple minded old man, I am wondering if the engine was ever checked for vibration when run without the fan belt, thereby eliminating fan, water pumps and generator or even a bad belt ?
10-18-2014, 12:40 PM | #51 | |
[QUOTE=Kube;964521]
From what I can read between the lines, the shop in question does not seem to grasp the thought about the rods wearing on the big ends. |
10-18-2014, 01:16 PM | #52 |
[QUOTE=Andy;964586]My rods were reconditioned to this extent: They were, of course, removed from the engine along with the pistons, cam shaft, and valves to clean the engine. The "big end" that I assume means the end that connects around the crank shaft, were all trued by machining the mating surfaces to reduce any oversize inside diameters so that the rods could then be machined to match the new bearings.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 10-18-2014 at 01:28 PM. |
10-18-2014, 01:23 PM | #53 | |
The mechanics that I'm now working with have all rebuilt hundreds of engines each (there are three of them). They have just never done a flathead so are having to learn some of the quirks of them. I do have full confidence that they will eventually get it right even though it may take them a bit longer and a bit more effort than it might take someone else. At least they no longer seem to want to charge me for their education. Since realizing that I can't count on them to get it exactly right on their own, because of the vibration problem, I have and will continue to print and deliver to them every suggestion (with insults redacted) that I have received for their assistance. They do read every word and hopefully they will consider modifying their diagnoses and treatment accordingly. Thanks for all of your contributions and keep them coming.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
10-18-2014, 01:37 PM | #54 |
I would buy a new flywheel from say Speedway and I can't see going with another pressure plate but why not.
I just looked a 8 rods here for my rebuild 5 were the same 3 other not the same. If the crank was done right all the same, now if some of the big ends were not. You could have difference size bearing in one or more. How many were scrap in your engine and were did the replacement come from . That's about 2k rpms mine had a knock. |
10-18-2014, 02:46 PM | #55 |
Hi Henry, I'm assuming you've tried running the unit without the belt(s), eliminating all the "driven" pieces??
You really should inspect the flywheel/clutch ass'y very closely first, this means having a very reputable shop with a decent balancer run up both pieces. We recently went through this dilemma with a customer in Maryland, he sent his flywheel/clutch ass'y to us for evaluation. We hadn't seen either piece before. Both were new and neither piece was balanced correctly. They were even worse when bolted together. We balanced the setup as a unit, indexed everything, and returned it. It WAS his problem, upon running up the pieces we knew it immediately. The balancer doesn't lie! One more item to remember, when working with a 14"/18" wheel ANY imbalance present is much worse at the 7"/9" radius than the 3" crank radius! It is much more critical at that span. You will tend not to "feel" a 10 gram imbalance at 3", you WILL at 7"/9" out! Thanks, Gary in N.Y. P.S. When you are working with all stock (internal) components there should not be a single issue changing components, you should be able to interchange cranks, rods, and even pistons. Should have no noticeable adverse effects. Resizing rods will have no effect, "cutting" the crank to an undersize will have no effect. Not "balance-wise"!
http://www.stromberg-bulletin.com/me...berg-equipped/ |
10-18-2014, 04:46 PM | #56 | |
10-18-2014, 04:57 PM | #57 |
I'm glad that they will work with you to get it right - that is the most important thing. Every single one of us and all shops make mistakes - it is WHAT we do about them and HOW we go about it that distinguishes the GREAT people and businesses from the others.
A flathead engine is internally balanced - so you can mix-match component assemblies (as long as the assemblies are balanced). Example, you can pull the flywheel/clutch out of one engine and swap them in another - no need to re-balance the internals of the engine as long as the flywheel/clutch are correctly balanced (and the crankshaft/rods/bearings/pistons/rings were also balanced as an assembly). Flywheels/Clutches: Some folks can/will balance each component independently of the other - such that there are no issues with indexing the clutch plate to the flywheel. But, it is not a big deal if a clutch plate is indexed/balanced to the flywheel - typically both are marked with punch marks to denote the index position. On most of the flatheads that I've built, the machine shops will specify/mark the index position - as it is EXACTLY how they were put together an ran on the balancer . . . so it only makes sense to keep them together and to install them in the same manner. Good luck with your quest and please let the Barn know what the problem actually was and how it was resolved. Take care, B&S |
10-18-2014, 05:24 PM | #58 | |
Most are balanced by themselves to "zero" so a change won't the balance. R |
10-18-2014, 05:32 PM | #59 |
From what I had noted in olhenry's earlier thread and from what these current guys did(did NOT do) , my hunch is it is NOT the clutch parts. If I were a betting man, I'd say it's the rods / pistons.
10-18-2014, 05:38 PM | #60 |
Here's a question that has been raised by the mechanic. Does any change need to be made to the crank when replacing the original cast iron pistons with newer aluminum ones? The original crank that has just gone back into the engine only ever had the original cast iron pistons used with it. When it was replaced with the other crank, the pistons were also replace with newer aluminum ones. Does that require any change to the crank?
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 10-18-2014 at 05:49 PM. |
Thread Tools | |
Display Modes | |
