12-08-2014, 03:00 PM | #1 |
8BA leaky thermostat housings?
Was running without 'stats and temp. would only get in the 160°-165° range now that weather is cooler; my understanding is low operating temp. promotes sludge buildup. Without the 'stats no leaks around the bottom of housings but since installing 'stats it leaks between housing bottom & gasket. I cleaned mating surfaces & used new gaskets & silicone sealer; any ideas to solve this problem?
12-08-2014, 03:18 PM | #2 |
Re: 8BA leaky thermostat housings?
Thermostats not seated in their recess in the gooseneck.
12-08-2014, 03:39 PM | #3 |
12-08-2014, 03:50 PM | #4 |
Wrong thermostats?
12-08-2014, 04:15 PM | #5 |
Not flat or the stat is not captured or housing is cracked or bolts bottomed out.
12-08-2014, 04:39 PM | #6 |
Wonder if there is a specific torque setting for the housings; I'll try again when I get the new gaskets. I noticed with the last set of gaskets, one side of the gasket has a peel off that leaves one side of the gasket sticky, would it make any difference which way the sticky side faces? Last edited by 36tudordeluxe; 12-08-2014 at 04:44 PM. |
12-08-2014, 04:49 PM | #7 |
Whats aftermarket the bolts or the housings? Do they both leak?....::Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
12-08-2014, 05:30 PM | #8 |
Replace the bolts with studs using sealer and your problem will go away.
12-08-2014, 06:54 PM | #9 |
The bolts are aftermarket SS & housings are aluminum; I didn't have a problem until I installed 'stats.
12-08-2014, 07:02 PM | #10 |
12-08-2014, 07:04 PM | #11 |
Thermostats facing right direction, seated correctly with a good gasket should not leak at six or seven pounds.
Bruce
Works good Lasts long time |
12-08-2014, 07:10 PM | #12 |
I experienced the same problem and found that stat had slipped down slightly and lower edge was out of the grove. You may need to center stat with your finger while tightening.
12-08-2014, 07:14 PM | #13 |
Bob, Go buy yourself some gasket material, its usually black for water. make sure its .060 + cut your own gaskets. use something like a non hardening sealant [like permatex No.3 here in Aust] don't over tighten, and after the first warm up just tweak it up again. Also wipe the inside of your hoses as you put them on with the non hardening sealant. You have checked the surfaces are flat, and the bolts are too long so that's done ...
12-08-2014, 08:58 PM | #14 |
Okay, here's picture of 'stats installed in housings; they're held in with a couple dabs of silicone to keep them centered. Will use Permatex as I have some instead of the silicone I was using on the mating surfaces. Thanks everyone for the help.
12-08-2014, 10:54 PM | #15 |
just use grey silicone sealer from napa and cover both sides of the gasket first (this is messy but gurentees the gaskets are covered with sealer) and then put the gasket on the housing with the stat in place and then set the housing on the head. by useing studs it will slip right on and no wiggling the housing to locate bolts that might move the gasket or stat. be liberal with the sealer and just wipe of the excess after the nuts are tightened in place. you might also try running teh housings accross some 600 grit wet or dry sand paper taped to a sheet of glass to be sure the mating surfaces are flat. you might want to use two of the same brand of stats also and drill a 1/16 air bleed hole on each stat to let the air out during fill up with water
12-08-2014, 11:34 PM | #16 |
Bob I recon half the problem is those gaskets you get with the peal off sticky side.
I don't think they are a good idea.
12-09-2014, 12:46 AM | #17 |
With the housings and stats like in the picture, put a straight edge across and see if the stat sticks down past (lower) then the flat on the housing. If the housing was flat filed or milled too much, the recess might not be deep enough anymore. That could explain why they don't leak when the stats are not there. Maybe new housings would have a deep enough recess to seal properly.
12-09-2014, 08:16 AM | #18 | |
Can you tell now if it's leaking at the stud or the gasket surface? Last edited by 19Fordy; 12-09-2014 at 09:11 AM. |
12-18-2014, 07:13 PM | #19 |
Problem solved, for some reason the non-hardening #2 Permatex worked. BTW, temp. is right where it should be with the 'stats installed.
12-18-2014, 08:04 PM | #20 |
I think your #2 [in USA]must be our # 3 [Aust], because I couldn't get it a NAPA when I was fixing a mates car when I was over.
Good to see it fixed
12-18-2014, 11:00 PM | #21 |
12-19-2014, 08:58 PM | #22 |
I used studs in the 8RT and they sure saved a lot of hassle trying to line up the capscrews and thermostat at the same time.
12-20-2014, 11:02 AM | #23 |
12-20-2014, 02:07 PM | #24 |
I have found that a couple of dabs of sealant on the housings to hold the stats in place works a every time now , after having one slip out and crack an aftermarket housing.
12-20-2014, 04:25 PM | #25 |
I do the same thing. If the housing needs sealant to stop a leak, something is wrong with either one of the surfaces. No sealant should be needed.
12-20-2014, 04:46 PM | #26 |
