Old 12-15-2010, 11:51 AM   #1
MBI Houston
MBI Houston's Avatar
Default How dumb is dumb
I was attaching my new cutoff switch to my new rebuilt generator and I tightened the nut on the generator post too tight and snapped it off right even with the top of the generator. Is there a way to get the post out of the generator and then replace it.
Thanks, Marshall
MBI Houston is offline   Reply With Quote
Old 12-15-2010, 12:08 PM   #2
Doug Cox
Doug Cox's Avatar
Default Re: How dumb is dumb
Yes, but you will have to disassemble the generator..
Doug Cox is offline   Reply With Quote
Old 12-15-2010, 12:09 PM   #3
Dan/Kzo
Dan/Kzo's Avatar
you will need to remove and disassemble the generator to gain access to the nut that securs it in place. a new post replacement kit is available from the vendors. a solder iron will also be required.
Dan/Kzo is offline   Reply With Quote
Old 12-15-2010, 12:27 PM   #4
Special Coupe Frank
Special Coupe Frank's Avatar
I wouldn't call that "dumb"... certainly regrettable, but I think many of us have done this.
Special Coupe Frank is offline   Reply With Quote
Old 12-15-2010, 01:28 PM   #5
Russ/40
Russ/40's Avatar
It takes a big old iron to solder those. I'd take it to an auto electric shop for soldering after you get it apart.
Russ/40 is offline   Reply With Quote
Old 12-15-2010, 02:03 PM   #6
Doug in NJ
Doug in NJ's Avatar
BTW, I once ordered a replacement terminal post from a reputable vendor, but it was not a proper copper one- it was steel with the common yellowish-colored zinc/chromate plating. So, if you order something, try to make sure it is the authentic type.
You can probably buy a 100-watt soldering iron for less than you would have to pay a shop to solder it. Look for places that sell stained glass supplies.
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 12-15-2010, 02:47 PM   #7
MBI Houston
Thanks for all of the help and kind words. I now have a new project to work on.
Old 12-15-2010, 07:49 PM   #8
ford1
there are hundreds of over educated college kids that go to school for over a year and spend thousands of dollars to learn what you learned in a few seconds, and it only cost an hour or so and a few bucks, not dumb, a cheap learning experience, no subtitude fo experience, just one more of lifes lessons about working on these old cars, lol
ford1 is offline   Reply With Quote
