03-28-2014, 08:29 PM | #1 |
16" Ford wheels
What tires r u using on the 16" rims????
03-28-2014, 11:06 PM | #2 |
Re: 16" Ford wheels
205 -80 8ply radials, No body roll due too soft side walls.
03-29-2014, 12:05 AM | #3 |
Re: 16" Ford wheels
Firestone Black wall Bias ply 650-16
03-29-2014, 04:26 AM | #4 |
Re: 16" Ford wheels
rear 750 16 front 550 16 firestones
03-29-2014, 10:46 AM | #5 |
Re: 16" Ford wheels
They will make your Model A look funny
03-29-2014, 11:58 AM | #6 |
Re: 16" Ford wheels
03-29-2014, 12:39 PM | #7 |
Re: 16" Ford wheels
Dunlop Grandtrek 215/70R16 radials. I run them as tubeless. This size was originally used on the RAV4.
1965 Lotus Elan S2 1930 Model A Sport Coupe |
03-29-2014, 03:27 PM | #8 |
Re: 16" Ford wheels
ditto post #7 size; cooper tires, tubeless
03-30-2014, 09:57 AM | #9 |
Re: 16" Ford wheels
if someone was going to order stock of the rack 16" black steel rim to fit a 1930 Model
A what would the bolt pattern measurements be and off-set if that apply's. What size tires are guys running to get close to stock diam. Also can we run a low cost radial or should we use bias plys ?
Where there's confusion, there's money! |
03-30-2014, 12:09 PM | #10 |
Re: 16" Ford wheels
Ford wheels from the 40's (and Merc) fit, 5x 5 1/2 is the bolt pattern I believe. Some later Ford p/up wheels also fit. Your choice either bias or radial, most run tubeless.
600x16, 650x16, radials a lot of fellows run P215-70R16's. Paul in CT |
